Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-06-2009, 01:19 PM   #1
Venting for a cape cod house
Hi, I have a cape code home built in the early 80's. There are open gaps between the gables in the crawl space. The builder had put regular insulation in the openings. I don't think this is allowing proper airflow. It also does not prevent mice from getting into the attic. My handyman want to put round styrofoam in there and caulk it closed. I am worried about air flow. On the back of the house it looks like there is styrofoam in between. I don't want this to effect the air flow in the attic. Thank you, Nancy [IMG]file:///zTransfer/Files%20From%20iBook/Documents/Pictures/100_48.jpg[/IMG]
Nan5 is offline   Reply With Quote
Old 05-06-2009, 09:59 PM   #2
If this is a typical cape setup, you have kneewalls on the second floor that transition into a sloped area that is parallel to the roof line. There's a small horizontal ceiling about 5-7 feet wide.
There should be an open area in each rafter bay that connects the crawlspace to the attic space above the horizontal ceiing. so the hot air can escape to the ridge and out of the house.
Mice do not get into the attic from the exterior. They get in the house from ground level and climb to the attic. Have the handyman seal up all the areas where they can get in.
You lost me about the, "sealing with round styrofoam". Where is that going?
Do you have a ridge vent? An attic exhaust fan?
Ron
Old 05-06-2009, 10:17 PM   #3
Xtreme DIY'r
Your other picture didn't post
Need more info on where the issue is
A pic of what the handyman wants to seal
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Termite exetermination tenting house. gante Pest Control 11 07-18-2010 11:44 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Roof Venting Issue, crawlspace supton Roofing 1 11-12-2008 07:44 AM
House Ventilation oldgrunt Roofing 8 11-11-2008 04:22 PM
