Ventilation Of Slab In Carpeted Rooms. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-14-2013, 02:13 PM   #1
Post
Ventilation of slab in carpeted rooms.
Moister barrier on old slab worn out and unable to stack solid objects on carpeted closet floors without having mildew/mold forming on carpet. Thought about using coated wire mesh shelving on floor which provides minimal footprint and about 1" bottom clearance for ventilation. Would welcome better ideas. Thanks.
Epo830 is offline   Reply With Quote
Old 11-14-2013, 04:10 PM   #2
Rewards Points: 13,466
I'm confused, what do you mean by the moisture barrier wore out?
How would it wear out if it's under the carpet?
If there's that much of a moisture problem there should be carpet in there. It's going to hold and give the mold a place to grow.
Installing louvered doors on the closet instead of solid doors should give you the air flow you need.
Old 11-14-2013, 07:08 PM   #3
Back in the day I was told there would be a moisture barrier laid down betwn ground and slab. Once holes developed in the barrier, probably cheap plastic, the concrete would absorb the ground moisture. good idea on the louvered doors. Thanks.
Tags
slab moister
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Lowering basement slab and installing drain tile diybrad Concrete, Stone & Masonry 0 04-26-2012 09:36 AM
Pier on slab cer2012 Building & Construction 0 04-16-2012 08:52 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
