Ventilation For Builtin Fridgefreezer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 05:09 AM   #1
Question
Ventilation for builtin fridgefreezer
I'm looking at IKEA's Frostig BCF228/64 integrated 70/30 fridgefreezer as it has auto defrost on both compartments - and a 5 year guarantee!
The FF has a depth of 560mm and width of 540mm. The housing unit is 570mm wide and deep, so I'm OK on the width, but is 10mm sufficient at the rear. I know I have to provide top and bottom venting of 200cm2.
IKEA can't answer this question and Whirlpool's (the manufacturer) customer support team can't find this model on their system.
redpirate is offline   Reply With Quote
Old 03-26-2012, 05:52 AM   #2
DIY staff
Rewards Points: 7,174
I moved this from introductions---hopefully someone can answer you---
Old 03-26-2012, 08:01 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
The documentation for that unit will specify ALL clearance requirements. If there is no mention of a rear or side space requirement then there is none.
PoleCat is offline   Reply With Quote
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 11:10 AM
