Venetian Dock Markers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 11:53 AM   #1
Lightbulb
Venetian dock markers
do any of you have an idea how I could construct the striped (almost like barber poles) poles you see on the Grand Canal in Venice(I have only seen photos) They will be in salt water and set in concrete in sand. I was thinking painted PVC pipe- 4" in diameter, slipped over rebar cemented in the river bed. Does this sound right. Again I am the designer and use minimum wage employees at my direction. Can't do it myself, not strong enough, don't know how to use very many power tools.
QUEENQUITETALOT is offline   Reply With Quote
Old 01-25-2012, 12:09 PM   #2
joed's Avatar
Rewards Points: 12,366
What is your location? Do these poles need to withstand frozen conditions?
Old 01-28-2012, 11:38 AM   #3
We are on the east coast of south florida, palm beach county
QUEENQUITEALOT is offline   Reply With Quote
Old 01-28-2012, 11:53 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Something like these right?
BTW they are usually referred to as Venetian mooring poles.
Andy.
AndyGump is offline   Reply With Quote
Old 01-28-2012, 11:55 AM   #5
Old School
Willie T's Avatar
You mean these?
See a video of installation here.... http://youtu.be/Gus7VSFckjw
Willie T
Old 01-28-2012, 11:56 AM   #6
Old School
Willie T's Avatar
I think these are all just ordinary painted wooden pilings.
Willie T
Old 01-28-2012, 11:59 AM   #7
Rewards Points: 13,450
Those are just wooden piers. You would have to get someone with a pile driver or a mud pump to set the poles then just paint them. You could also buy PVC pipe, paint them and just slide them over the wooden poles.
Old 01-28-2012, 12:13 PM   #8
Too Short? Cut it Again!
If you use PVC, prime with Rustoleum plastic primer first. It comes in both rattle cans and liquid. Then follow with a 100 percent acrylic exterior paint. Painter's tape should work for the striping.
As for the finials, you might not get the exact match but a lumber yard or---argghh, ick---box store may have something for fence posts that is close. You should see what size those are before getting your round stock.
Old 01-28-2012, 03:10 PM   #9
Msradell's Avatar
Rewards Points: 170
I think a much simpler way to stripe them would be to use heavy duty vinyl tape for the stripes. The PVC is already white for the background and the tape can be purchased up to 4" wide. It would probably also hold up better than paint.
Msradell is offline   Reply With Quote
Old 01-28-2012, 04:22 PM   #10
Great idea!Still have to deal with the finials but some painter's tape and rattle cans of something like Krylon Fusion or the Rustoleum plastic paint will work fine for them.
Old 01-28-2012, 05:13 PM   #11
Old School
Willie T's Avatar
I think you will find that tape holds up very poorly out in Florida sunlight... VERY poorly.
Willie T
Old 01-28-2012, 08:49 PM   #12
venetian dock markers
Thanks to all. I will paint the pvc. Will have to paint the white also as I don't like anything thing that looks new. Andy, thank-you very much. I would not have remember "Venetian Mooring Poles" You all are just great, will post pictures when complete. Much to do....
help wiring a dock seacern Electrical 20 05-30-2016 01:04 PM
running 220V to dock for float lift. Uncle Mike Electrical 1 09-28-2011 04:21 PM
Preserving dock pilings with cement jacket? SaltyDawg Building & Construction 1 09-10-2010 02:48 AM
Solution for service on a lake dock rdy2go Electrical 3 05-30-2009 11:07 AM
Floating dock walk attachment pookemp Building & Construction 5 01-04-2009 06:48 PM
