Vaulted Ceiling Drip Streaks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2014, 01:39 PM   #1
Vaulted Ceiling drip streaks
My vaulted ceiling has sticky yellowish streaks running from the highest part of the ceiling down about 10 feet and ending in what looks like a drop. This all started after putting on a new roof about 5 years ago. What can I do?
islander818 is offline   Reply With Quote
Old 01-19-2014, 02:29 PM   #2
Rewards Points: 26
You don't say where you are located and it might have a bearing on it..
In northern / colder areas when roofing is applied you should use nails that barely protrude thru the roof sheathing.
The reason being.. They will conduct cold faster than the roof itself. Now IF they protrude, say a half inch or so, and there is any moisture in the rafter bays then they will cause condensation. Usually this will evaporate before doing any damage. However... If it's real cold for a prolonged period they will form "ice balls". I have seen them bigger than a golf ball. Now when these puppies melt they're going to bleed thru about anything.
Wait for a cold spell & see if you have nails making ice up there.
Good Luck & hope this helps.
..Jon..
J Thomas is offline   Reply With Quote
Old 01-19-2014, 02:39 PM   #3
Rewards Points: 65
Vaulted ceilings are tricky. Not much space for venting to allow moisture to escape. Do you know if there was any sort of venting in the old roof? If the new roof was installed without venting, you could end up with condensation that would drip onto the ceiling material.
chiraldude is offline   Reply With Quote
The Following User Says Thank You to chiraldude For This Useful Post:
Live_Oak (01-20-2014)
Old 01-20-2014, 08:25 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Gotta know where you are and climate.
Could be either a leak or condensation.
Old 01-20-2014, 08:34 AM   #5
joed's Avatar
Rewards Points: 11,534
Picture would be very useful. Are these streaks possibly in line with the ceiling joists? Could be shadowing do to moisture collecting on the colder rafter areas and collecting dust.
Old 01-20-2014, 08:47 PM   #6
Rewards Points: 850
We see that more and more these days and people keep painting them and wonder why they come back.
Tags
condensation , vaulted ceiling
framing a vaulted ceiling dwoolver Building & Construction 5 05-26-2012 05:40 PM
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 10:25 AM
Vaulted ceiling moisture fride360 Building & Construction 7 05-06-2012 04:14 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
