Vapour Barrier HELP!!!!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 05:16 PM   #1
vapour barrier HELP!!!!!
the girlfriend and i bought a fixer uper. aside from our attic, there is no insulation in any of our walls. now, we are about to tackle our spare room. Here's my question/concern.
We are pretty sure our bricks are leaking. our wall has evidence of water damage. can i the following
exterior wall, vapour barrier, insulation, vapour barrier, drywall.
i know you generally just do, insulation, vapour barrier, drywall. any help would be appreciated. if that is a bit confusing. let me know. ill try to explain it better.
06GT is offline   Reply With Quote
Old 02-22-2010, 06:43 PM   #2
ccarlisle's Avatar
Look, we here to answer you - not try deciphering your garbled texting because you're busy doing something else...what are you asking?
Looks like you're asking if 2 vapour barriers can be placed???
No!
Get with it if you want people to help
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-22-2010, 06:44 PM   #3
Rewards Points: 5,336
You might want to proof read the post before to hit the,"post" button.
Ron
Old 02-22-2010, 08:12 PM   #4
MJW
No!
Actually our current code here is essentially doing just that. Vapor barrier inside and outside the walls. We are sealing all walls and I really don't agree with it.
MJW is offline   Reply With Quote
Old 02-22-2010, 09:59 PM   #5
By exterior wall do you mean the brick ?
Is it just brick...then 2x framing?
Old 02-23-2010, 05:51 AM   #6
ccarlisle's Avatar
MJW:
Thanks for that info...two vapour barriers? i.e a vapour sandwich? from what I have read, that's not a good idea just from the scientific perspective, let alone opinions of code inspectors but OK. Maybe you see something we don't.
Does your code specifically allow, I dunno, say, two 6mil plastic vb's on both sides of a wooden stud/drywall wall in cold climates, or are they a bit vague about it? I suppose if the vb's were perfect, no moisture would enter anyway so no deterioration - but that's a perfect situation...
Old 02-23-2010, 06:08 AM   #7
Rewards Points: 4,584
you bought a house w/o knowing ANYTHING about home ownership ? ? ? relax - that happens every day,,, think it comes from wanting a home and/or watching too much hgtv & thinking you can do it better/smarter/cheaper than the pro's,,, what you don't see portrayed is their learning curve & loss's
listen to carlisle - IXNAY on 2 vapor barriers,,, point those leaking brick walls FIRST,,, if you don't, you'll be replacing all the wet insulation &, possibly, have your mortgage holder breathing down your back !
Old 02-23-2010, 06:16 AM   #8
ccarlisle's Avatar
LOL...Always good reading "itsreallyconc's" posts so early! gets the day going right. We're expecting a foot of snow today...
Old 02-23-2010, 08:01 AM   #9
MJW
MJW:
Totally agree. All penetrations are sealed with foam inside and out. Poly inside, OSB outside with no spacing. I consider that a vapor barrier.
I have pulled nails out in the field on a wall and found them to be all rust. We have alot of work on our hands in the future. It wouldn't be the first time that the "scientists" and law makers said, "I guess we were wrong before, now do it this way"........
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Roxul without vapour barrier? giannit Building & Construction 8 01-26-2010 04:39 PM
Densshield and Vapour Barrier rayf01 Building & Construction 6 01-01-2010 12:55 PM
Drylock, Typar and Vapour barrier? fubar79 Building & Construction 5 11-06-2009 11:35 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
