Vapour Barrier - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-19-2006, 12:36 PM   #1
Vapour Barrier
Does anyone know of a vapour barrier (manufacturer) that can withstand 90 degC?
mhervy is offline   Reply With Quote
Old 10-19-2006, 12:58 PM   #2
no worries, found one
Old 10-19-2006, 12:59 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Vapour Barrier
Materials have a wide range of permeability and there is no magic number (perm rating), except for some go-no-go numbers written into a minimum standard code. Some poly is classifies as a "vapor barrier" and some is not, all because of a difference of 0.5 mils. Even a breathing paint can be a "vapor barrier".
What perm rating do you need?
Is it for a true barrier or just to meet code requirements?
What are you going over and how are you attaching or pentrating it?
90C is not impossible, but it is a challenge is you want a true sealed vapor barrier w/o pentrations.
concretemasonry is offline   Reply With Quote
Old 10-19-2006, 02:00 PM   #4
thanks man, i know what a vapour barrier does and I have to cover pot light box's with it, i've found a manufacturer in canada that has a vapour barrier capable of this.
Old 10-19-2006, 02:07 PM   #5
i have to penetrate it with wire...
moisture behind vapour barrier piperboy General DIY Discussions 9 10-21-2008 01:49 PM
Double Vapour Barrier? canadaclub Building & Construction 4 01-14-2007 06:42 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
Vapour Barrier Around Pot Light Box mhervy Electrical 4 10-03-2006 04:29 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 11:13 AM
