Vapor Barrier Confusion! ??? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 12:43 PM   #16
Sorry to bring this back from the dead. But it's the best discussion I've found on the topic and I've found no answers.
If Roxul is used as insulation, and a poly vapor barrier used, then what should be used on the outside of the house during a renovation? The job I'm looking at is removing 50yr old aluminum siding to expose homosote sheathing underneath. Depending on the condition of that I might replace the homosote with new sheathing. But I don't want to use a product like Tyvek Housewrap that would create a double vapor barrier.
Any ideas?
mage182 is offline   Reply With Quote
Old 08-03-2011, 08:40 PM   #17
Rewards Points: 2,638
I don't think I have enough knowledge on the subject to recomend what you should be using, but Tyvek is not a vapor barrier. It breathes. See link below:
http://www2.dupont.com/Tyvek_Weather..._homewrap.html
SPS-1 is offline   Reply With Quote
Old 08-04-2011, 08:02 AM   #18
Thanks. I also received this response from Roxul directly. The Tyvek should work fine.
The Tyvek house wrap that most builders are using is only an air barrier, it will not act as a vapor barrier the same way the plastic you installed on the inside did. The Tyvek will help control air flow and create a tighter building envelope. There is a number of air barrier products on the market and as long as they are just an air barrier there will be no problem using one.
If you have any other question please feel free to contact Roxul.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Outlet/Circuit Tester Result => Confusion JPM Electrical 2 08-18-2010 08:04 PM
Basement Sub-panel neutral/ground confusion rstain Electrical 12 03-12-2010 08:24 PM
Attic Framing Confusion... Jamison1114 Carpentry 23 12-16-2009 02:17 PM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 06:21 PM
