Using The Wrong Molding? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 12:10 PM   #1
Rewards Points: 480
using the wrong molding?
went with 2 long pieces of molding across the top, a 45 degree lap joint (?) connects them.
the molding i purchased has a tapered edge. it is pointing down on the top piece and to your left on the vertical piece. i beveled the edge of the vertical piece to avoid having to miter the top pieces (i need to shorten this vertical piece). i initially tried to miter the top pieces, breaking the long run across the top, and it didn't look right.
i have three sections for screens (2 of 3 pictured below), so the second section will not have the tapered edges on the inside. 3 questions-
should i break the 16' top and bottom pieces into sections and miter each screen section?
or should I continue with the beveled vertical pieces, avoiding the miters?
and finally, can i continue with the tapered molding, or should I purchase new molding?
thanks so much!
(you'll notice in the old bottom pic that I initially used miter cuts).
joetab24 is offline   Reply With Quote
Old 01-29-2011, 05:08 PM   #2
Rewards Points: 5,336
Flat stock 1x 4's or 5's would be simpler to work with instead of using base molding with a profile. It would eliminate the joining issues you seem to have there.
Ron.
Old 02-13-2011, 12:20 PM   #3
Rewards Points: 480
is it just a matter of preference or am I doing this incorrectly? should I go wider with the vertical piece, so that I cover more of the end of the door casing? just trying to get this straight before I start making a bunch of cuts... thanks so much! I may actually get this project done by the spring
Old 02-13-2011, 01:57 PM   #4
Are you trying to cover all the pressure treated lumber? If you are, you apply the interior pieces first(like the door jamb position). Then you apply the face pieces to cover the edges.
The picture shows the face piece butting up to the door stop. Typically the door trim(face frame material) covers the jamb edge.
You're using the wrong terminology in the picture. Partly because you didn't put the screen door in a typical jamb. In your case what's orientated like a jamb is actually a stop for the door. So you actually have a face frame piece butted to a stop piece. The stop piece should be ripped to come even with the pressure treated wood. There should be another flat stock piece on the other side of the pressure treated wood you're using as a door frame. The face frame piece should cover both edges. You usually have the face frame piece 1/4" narrower to leave a reveal of 1/8" on each side.
Look at the trim work in the house and use that as a guide.
Or you can leave no reveal and cap it to the ends. Your call.
Ron
Old 02-13-2011, 02:32 PM   #5
Rewards Points: 480
thanks ron
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Is this the wrong type of molding for walls? dma550 Carpentry 8 07-15-2009 10:55 AM
