Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-26-2008, 10:59 AM   #1
using TREX DECKING in a sauna
I am building an indoor sauna and was thinking of using TREX for my benches as there will be moisture and heat in the room
any thoughts on why I SHOULDN'T use it????
smokyadam is offline   Reply With Quote
Old 01-26-2008, 07:03 PM   #2
Well a sauna will get up to 120 degrees I'm guessing and your house will probably be at the coldest 60 degrees. Thats only a 60 degree swing. Not that much considering. Now if your sauna is in your unheated garage and you live in Canada We could be talking about -20 degrees now your talking 140 degree swing. Things could get ugly if this is the case.
Trex does expand and contract A LOT and I'm assuming your application is the former, so you should be OK. Assuming again that your sauna is not more than 16 foot long and assuming that you will install the Trex with the sauna off, you should be OK. Use full length pieces ONLY and make sure to cut your Trex short by about 3/8s to 1/2 inch and center in the space.
I also suggest Stainless screws which will hold up better in moist conditions. Also sweat is extremely corrosive and stainless will hold up better under that.
GL and happy building!
jiggyjack is offline   Reply With Quote
Old 01-26-2008, 10:38 PM   #3
remodeling pro
Besides the fact that it is junk? Search the decking threads at the sister pro site "Contractor Talk" before buying it. For about the same money you could use either clear heart redwood or teak.
troubleseeker is offline   Reply With Quote
Old 01-27-2008, 12:28 PM   #4
thanks for the two replies, i know a couple of guys who have built their decks with it and it came out great, it's now been several years and it looks as good today as it did the day it was installed by regular guys.
i was just looking for thoughts from other people and btw i am massachusetts just north of boston
Old 01-28-2008, 09:19 PM   #5
robertcdf's Avatar
Trex works in some place and some places its garbage. Around here its garbage. I personally like Correct Deck CX.
robertcdf is offline   Reply With Quote
Old 01-31-2008, 03:25 PM   #6
Custom Deck Builder
BuiltByMAC's Avatar
TREX and other composites tend to get a little floppy when heated. Make sure you support the TREX boards every 8" - 12" if you use them.
Why would you want to sit on hot plastic? I could think of less comfortable benches, but not many. Composite decking gets very hot to the touch exposed to sun - I would wonder if it wouldn't get too hot to sit on in a sauna situation.
I would think cedar or redwood would be a much better choice.
Mac
BuiltByMAC is offline   Reply With Quote
Old 01-31-2008, 04:08 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
....any thoughts on why I SHOULDN'T use it????
Not really off-hand
But just don't think it's not going to get mold/mildew, which is a common mis-perception for some reason
It's a composite...there's plenty of mold food (natural material) in it
It molds and mildews if not maintained
slickshift is offline   Reply With Quote
Old 01-31-2008, 08:00 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I will say this, I have seen multiple Trex decks with mildew/mold problems.
About 4 weeks ago, we ripped down a deck with moldy Trex, that was built by a home owner. (The deck was not built to code, and the decking was unsalvagable due to the mold).
Neither I, nor any fellow GC's that I know and deal with, will recommend Trex.
I especially, would not recommend it in any areas that are prone to heavier amounts of dampness and moisture.
Here's a close-up shot of the Trex boards on the deck we demo'd. The black spots (speckled all over) are the mold. There was more on the main area of the "deck":
- Build Well -
Old 02-01-2008, 10:52 PM   #9
robertcdf's Avatar
That looks a lot like Choice deck and not at all like Trex that I have ever seen. Are you sure it was trex brand?
Old 02-02-2008, 06:25 AM   #10
I could be wrong, but that is what the Home Owner told us.
- Build Well -
Old 02-02-2008, 10:54 AM   #11
Custom Deck Builder
BuiltByMAC's Avatar
Good call, Robert. Contours is the only TREX board that has the grooves on the underside and it's only got two grooves, not 3.
Mac
Old 02-02-2008, 12:02 PM   #12
robertcdf's Avatar
I pay close attention to every little detail with composite decking. I like to be able to tell what brand it is from the street. That way when I go to a house and people say "The people next door have that trex stuff and it looks like crap" I can say "that is weatherbest and it is crap, we use much better stuff."
TREX decking extremely disappointing KHL General Discussion 263 08-30-2012 01:18 PM
Trex decking LL1 General Discussion 56 09-30-2011 10:55 PM
Trex Decking Discoloration ozarkee General Discussion 24 03-23-2011 10:26 AM
Anyone with TREX decking come in! tigerbalm2424 General Discussion 19 05-22-2010 11:32 AM
Survey on Trex composite decking TC1 Carpentry 22 04-13-2010 02:21 PM
