Using Closet Doors For Shelves - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 08:24 PM   #1
downrightart's Avatar
Rewards Points: 150
Using Closet Doors for Shelves
Has anyone ever used their closet doors for shelving? As I was putting spackling on my closet walls to fill in the holes that were left due to pulling out the metal shelving, I noticed the back of the closet doors are flat. I only need four shelves and they have four panels. Ummm......
Have any of you used your closet doors? I realize if I use them I will have to saw them off some. Also, how do you suggest I mount these? They feel kinda hollow. I just wondered if I could use them as floating shelves. I realize I'd probably have to use end brackets. I've never done floating shelves, but I like that they have a more custom look without the brackets underneath.
Anyone here try that? How did it work out?
downrightart is offline   Reply With Quote
Old 04-02-2010, 08:57 PM   #2
Rewards Points: 5,336
The term. "floating shelves" doesn't describe your scenario. You can install wall cleats on 3 sides of the closet to support the shelf. I would reinstall the end stiffener to provide adequate support.
Ron
Old 04-02-2010, 09:10 PM   #3
Rewards Points: 150
Ron
Oh. Well, I thought one end had to be open (the inside hollow) to install a floating shelf into the major wall. It's been awhile, but I thought that's what I read and saw in some illustrations. I could be wrong. Like I said, I've never installed them.
The shelves will be 73 inches long, that's why I wanted some stability in the middle and yet it still have that "floating" look. Oh well, maybe it can't be done.
Thanks for responding Ron. I think I need to read up on my old Handyman booklets again!
Old 04-02-2010, 09:16 PM   #4
Learning by Doing
Leah Frances's Avatar
Hollow core doors don't make good shelves. I'd check out your local hardware store or lowes or HD and look at brackets and shelving options. There are MANY out there.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-02-2010, 09:29 PM   #5
You can't use the doors as a floating shelf.
The way I described their use is the only way it can be done.
Ron
Old 04-02-2010, 09:37 PM   #6
Rewards Points: 150
Man, I thought I could recycle these doors or use them in some way. I guess I could make another wall screen!
Sorry. That's another project that I have to finish------stripping this wall screen my husband and I made to hide the back of the entertainment center in the living room. It no longer matches my newly painted decor.
Well, I'm on the right site anyway!
Old 04-02-2010, 09:40 PM   #7
Rewards Points: 150
Ron
I realize that now Ron. Thank you so much for describing how I could hang them.....if they are durable enough. Which now, I'm wondering if they are.
Old 04-02-2010, 09:43 PM   #8
jlhaslip's Avatar
Rewards Points: 2,884
I use old bi-fold doors as shelving in the shop.
The ones for heavy stuff have 4 full depth supports. The ones for lighter stuff use two supports and a back cleat. All full depth of the door/shelf.
I also use the supports to hold another smaller shelf.
Not really 'floating shelves'...
I'll see if I can find a picture to show you.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-02-2010, 09:51 PM   #9
There is no such thing as a "universal shelf". You build a shelf for an intended use. A hollow core door would be a medium use shelf at best. It would need a frontal support for anything above light duty.
Ron
Old 04-05-2010, 11:44 AM   #10
biggles's Avatar
if you ran lenghts of 2x4 across the back of the closet...catching wood studs every 16" then cut the doors to slide straight in and lay ontop of that horizontal 2x4 and wood screw it down it will work.i have a 8" pine shelf behind my couch in the living room with 100 lbs of books on it ..if you screw that 2x4 into the wall joist it will be solid to store on
Old 04-05-2010, 01:13 PM   #11
You are comparing apples to oranges, structurally speaking.
It will never work for a number of reasons:
1 The structural rigidity of a door comes from the perimeter frame.
-You want to remove part of it
2 The door skin has no structural function in a weighted, horizontal plane.
3. The doors extended projection would barely support it's own weight.
-You think fastening a 3/16" door skin to a secured 2x4 will hold up anything?
4 Doors are constructed to operate in a vertical plane. While they can be used as shelves and tables, they need to be properly supported to do so.
Ron
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 10:09 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Closet doors? ponch37300 Building & Construction 5 02-27-2008 07:55 PM
Closet Doors for non standard closet dimensions jherschel Carpentry 7 02-22-2008 04:45 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
