Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-08-2010, 07:37 AM   #1
Dick
Urine Smell
I purchased a house 2 months ago. Express purpose: buy/fix/flip. It had been broken into prior to purchase. Some zero percenter's and/or their pit bulls had pis**ed on the then existing carpet. Despite the fact that the place is now gutted, the smell lingers. Apparently it penetrated the carpet in some places and got down to the wood floor underneath. Anyone have a clue how to neutralize the smell? I'm concerned that when it comes to installing new carpet, this problem will come back to haunt me. Some people here who have run into the same thing have reassured me that once I close things back up/paint, etc. The smell will go away. I'm not sure... Thanks.
RMCarner is offline   Reply With Quote
Old 12-08-2010, 08:05 AM   #2
the Musigician
DangerMouse's Avatar
Urine Smell
We had a similar situation. I ended up using shellac on the floor to seal the smell in. It worked fine.
(although with the pad and carpet on top, we probably would have not smelled it any more anyways, but.... better safe than angry wife.)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
RMCarner (12-08-2010)
Old 12-08-2010, 08:12 AM   #3
Dick
Urine Smell
(although with the pad and carpet on top, we probably would have not smelled it any more anyways, but.... better safe than angry wife.)DM
That's a great suggestion! I've used shellac for years as a furniture refinisher to serve as a inter-medium layer to keep contaminants from bleeding through the lacquer top-coat. What do you recommend: a gallon of Zinzler's maybe cut 50% with denatured alcohol and just pour it over the floor?
Old 12-08-2010, 08:13 AM   #4
40+yrs Paint Trades
Urine Smell
There's an enzyme cleaner that works wonders. I use it on my rental properties when a tenant has a wayward dog or cat. Sometimes 2-3 applications are required.
http://www.odorgone.com/
Available at Costco and similar products are available at Janitorial supply shops.
I've also painted wood floors with Kilz, to seal out the smell.
hoz49 is offline   Reply With Quote
The Following 2 Users Say Thank You to hoz49 For This Useful Post:
mae-ling (12-17-2012), RMCarner (12-08-2010)
Old 12-08-2010, 08:22 AM   #5
the Musigician
Urine Smell
We tried (I believe it was called) Urine-B-Gone but the smell of THAT about made me sick, so I went with shellac.
I just used Bullseye, full 'strength' with a roller.
DM
Old 12-08-2010, 08:30 AM   #6
Dick
Urine Smell
Thanks for the link to this product. I also have rentals and will check it out. In the meantime, I'm gonna also take Danger Mouses's suggestion and slather the exposed areas with a shellac based material. I think I have a gallon of Bullseye in the shop. If not, I'll pick one up at a box store. I can't stand the smell. You'd think after being in the space for over a month working one would get used to it... But it ain't happening.
Old 12-08-2010, 03:25 PM   #7
Urine Smell
My house had the same problem, there were actually areas of the subfloor discolored from the urine. Nasty. The house reeked even after all the carpet had been removed. We primed the entire subfloor with kilz and the smell was totally gone. It sucked to do, but was worth it! The smell was so bad the first time we viewed the house we went around and opened the windows!
Evan
240sx4u is offline   Reply With Quote
Old 12-08-2010, 08:35 PM   #8
Dick
Urine Smell
Originally Posted by 240sx4u View Post
My house had the same problem, there were actually areas of the subfloor discolored from the urine. Nasty. The house reeked even after all the carpet had been removed. We primed the entire subfloor with kilz and the smell was totally gone. It sucked to do, but was worth it! The smell was so bad the first time we viewed the house we went around and opened the windows. Evan
LOL about opening the windows. It was 27 degrees here today and I opened a window. I'll try sealing off the floors that are now exposed. I can see stains on the wood that must be from the piss leaching through the carpet. Thanks.
Old 12-08-2010, 08:41 PM   #9
Urine Smell
I typically just remove the subflooring that is covered in urine.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 12-08-2010, 08:43 PM   #10
Dick
Urine Smell
No sub-flooring to remove. I'm staring at tongue and grove pine..
Old 12-08-2010, 09:03 PM   #11
Urine Smell
You can "cover up" a smell but it doesnt mean its gone. Wood soaks in odor and its hard to get it out. Least thats my experience.
Old 12-08-2010, 09:07 PM   #12
Dick
Urine Smell
You haven't said what you have done other than remove a sub-floor? Two suggestions that have worked for others on this list: sealing off odor with a shellac based sealer, and using a product like Odor Done.
Old 12-08-2010, 10:57 PM   #13
Urine Smell
Other than removing the flooring, I would get an enzyme to kill the acidity of the urine.
Old 12-09-2010, 08:05 AM   #14
Dick
Urine Smell
There's a company nearby that specializes in professional cleaning products to the trades like Paul Davis and the like. One time, I had a furnace puff in one of my buildings. I wouldn't wish the consequences of one of these on an enemy -btw.. I was able to purchase some chemical sponges and a special solvent that dealt with the oily soot residue, which migrated up into all of the apartments. What a deal that was! Anyway, I'll call them and see what they are selling to the Trades.
Old 12-10-2010, 12:22 AM   #15
Urine Smell
We had this problem with our rental, the urine was even in the dry wall. We ended up spraying the enzyme stuff AND repainting. Worked like a charm.
superwoman is offline   Reply With Quote
Bad smell in crawl space. John_W General Discussion 30 06-07-2013 02:57 PM
Smell coming from all floor registers. John_W HVAC 9 06-27-2010 10:57 AM
Urine smell around dryer juliadc Appliances 4 05-30-2010 08:49 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Smell when boiler runs? dave12345 HVAC 9 04-21-2010 09:03 AM
