UPVC French Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 03:26 AM   #1
uPVC French Doors
Hi folks,
At my friends home there is a large upvc window with a small upvc window above (which opens). I would like to remove the larger upvc window and the wall beneath it, and put in french doors of the same width (4ft) - (opening into a back yard).
I would like to leave the small window in place and fit the door under it- since the room needs as much light as possible.
Would this be a possibility or would I have to buy purpose built uPVC french doors with a window on the top?
foster01 is offline   Reply With Quote
Old 02-26-2009, 05:56 AM   #2
Assuming the door opening will allow a standard size door(usually need 84" height), probably. There is likely already a header over the opening, so that part is taken care of. There may be heat ducts or heaters and wiring in the wall to deal with, but those things usually have a solution.
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Installing french doors in a load bearing wall johnsan Building & Construction 6 01-03-2009 04:59 PM
Pair of French Doors/ one is warped nyc1dxo Carpentry 8 04-28-2008 07:10 AM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 10:35 AM
