Upflush Toilets, And Sewage Ejection Systems - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 06:20 AM   #1
upflush toilets, and sewage ejection systems
I have a half bath in my basement with a normal toilet. I have a sink, washer and dryer. The toilet connects to the main drain below the concrete floor but the sink, washer and dryer are drained above the floor hidden behind a wall. I am thinking about installing a shower and was told I need a sewage injection system to do this if I do not want to be chopping up the floor. My question is, sewage ejection systems require the digging of a sump, so what would be the point? I still have to dig up the floor to do it...is it possible to put the pump "in line" so I don't have to dig up the floor. I also assume I would need some sort of mascerator to chop up hair.
you can email me..
skrimpster at aaol.com
Skrimpy is offline   Reply With Quote
Old 03-04-2007, 07:53 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Skrimpy .....I sent you an email (through this forum) about a low-profile sewage ejector system.
No digging needed, as long as you have some headroom... Here it is:
http://www.accentshopping.com/produc...ReturnUrl~.asp
I believe that there are a few other manufactures out there who also put out a similar pump. If you don't try ordering one direct, then look at a plumbing supply house.
Good Luck....
- Build Well -
Old 03-08-2007, 07:16 PM   #3
you can email me..
http://www.saniflo.com/?gclid=CNfK_b...FREPSQodKBVK_A
vhehn is offline   Reply With Quote
Old 03-08-2007, 07:45 PM   #4
Originally Posted by vhehn View Post
Ah...yes, I totally forgot about that unit...thanks for posting that...
- Build Well -
