Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-26-2009, 01:16 PM   #1
Unusually high electrical bill
I'm looking for help diagnosing unusually high electrical usage in my home. There is no obvious reason for the increased bill. Thanks.
Henryjr is offline   Reply With Quote
Old 08-26-2009, 01:24 PM   #2
Xtreme DIY'r
Do you have a well or other type of pump?
Old 08-26-2009, 01:29 PM   #3
Learning by Doing
Leah Frances's Avatar
No joke. Are there any unexplained wires running from your meter, house, garage? Electric theft does happen.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-26-2009, 01:36 PM   #4
Yes both. Inground pool.
Old 08-26-2009, 01:37 PM   #5
Thanks Leah, but there are no unusual wires ... Think it's an "inside" job!
Old 08-26-2009, 01:42 PM   #6
Xtreme DIY'r
Can you tell if the well pump is running a lot?
Some have posted about leaks & well pump running almost non-stop to keep up pressure
Pool pump if failing or obstructed water line could be causing back presure & making the pump work harder
Old 08-26-2009, 02:15 PM   #7
LeviDIY's Avatar
PEPCO in Maryland and DC area bills unexpectedly spiked this past winter... when asked they said "must be your usage" but recent news articles are out that meters are malfunctioning... I smell bill credit soon.. check out news on your power company.
LeviDIY is offline   Reply With Quote
Old 08-26-2009, 02:29 PM   #8
Thanks for your help. Will look into pumps.
Old 08-26-2009, 02:56 PM   #9
Three months ago I had a unually high bill - nearly double the norm - Ouch!
Found the timer for the pump/filter on my inground pool had gone bad and causing it to run way too many hours in a day. A trip to a big box store for a replacement timer and all was good again.
Old 08-26-2009, 05:52 PM   #10
It was a dark and stormy
Yoyizit's Avatar
http://www.eia.doe.gov/emeu/consumpt...on_tables.html
You can also use your wattmeter as an ammeter, if you're interested in isolating the problem to a specific appliance.
http://www.wholesalesolar.com/pdf.fo...ower-table.pdf
If you post a few samples of normal bills and of high bills, the chance of this happening "by chance" can be figured by using
http://en.wikipedia.org/wiki/Analysis_of_variance
somewhere I have a disk with a BASIC program on it that does this.
Old 08-26-2009, 06:04 PM   #11
Teenage son?
http://www.hydroempire.com/store/index.php
jerryh3 is offline   Reply With Quote
Old 10-19-2010, 12:45 AM   #12
POWER COMPANY CORRUPTION.
Yes, it happens. I hope you are not in a "Cooperative" and you are where they regulate.
You can get a Kill o Watt EZ and test the appliances yourself to make sure there is nothing on your end. Document everything.
If you have a new digital meter, several "experts" have documented faulty installation causing high bills.
RStephen is offline   Reply With Quote
Old 10-19-2010, 08:17 AM   #13
Jack of all - master none
hyunelan2's Avatar
Have your bills been "actual" reads or just "estimates?" Here, ComEd does no read the meter every month. They only read the meter like once every 3 months and issue "estimated" reads in-between. I have had the occasion where they underestimate the reads, then the actual read is high and I have a high bill to catch up.
hyunelan2 is offline   Reply With Quote
Old 10-19-2010, 09:05 AM   #14
fabrk8r
fabrk8r's Avatar
Do you happen to have a heat pump?
I had one case where the A-coil had a leak and the homeowner didn't realize it until they got a really high electric bill because the home was being heated by emergency heat for a month.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
How high for front light? Not Sure Electrical 2 08-07-2006 12:37 AM
