-   -   Unusually high electrical bill (http://www.diychatroom.com/f2/unusually-high-electrical-bill-51728/)
Henryjr 08-26-2009 12:16 PM
I'm looking for help diagnosing unusually high electrical usage in my home. There is no obvious reason for the increased bill. Thanks. :(
Scuba_Dave 08-26-2009 12:24 PM
Do you have a well or other type of pump?
Leah Frances 08-26-2009 12:29 PM
No joke. Are there any unexplained wires running from your meter, house, garage? Electric theft does happen.
Henryjr 08-26-2009 12:36 PM
Yes both. Inground pool.
Henryjr 08-26-2009 12:37 PM
Thanks Leah, but there are no unusual wires ... Think it's an "inside" job!
Scuba_Dave 08-26-2009 12:42 PM
Can you tell if the well pump is running a lot?
Some have posted about leaks & well pump running almost non-stop to keep up pressure
Pool pump if failing or obstructed water line could be causing back presure & making the pump work harder
LeviDIY 08-26-2009 01:15 PM
PEPCO in Maryland and DC area bills unexpectedly spiked this past winter... when asked they said "must be your usage" but recent news articles are out that meters are malfunctioning... I smell bill credit soon.. check out news on your power company.
Henryjr 08-26-2009 01:29 PM
Thanks for your help. Will look into pumps.
vsheetz 08-26-2009 01:56 PM
Three months ago I had a unually high bill - nearly double the norm - Ouch!
Found the timer for the pump/filter on my inground pool had gone bad and causing it to run way too many hours in a day. A trip to a big box store for a replacement timer and all was good again.
Yoyizit 08-26-2009 04:52 PM
http://www.eia.doe.gov/emeu/consumpt...on_tables.html
You can also use your wattmeter as an ammeter, if you're interested in isolating the problem to a specific appliance.
http://www.wholesalesolar.com/pdf.fo...ower-table.pdf
If you post a few samples of normal bills and of high bills, the chance of this happening "by chance" can be figured by using
http://en.wikipedia.org/wiki/Analysis_of_variance
somewhere I have a disk with a BASIC program on it that does this.
jerryh3 08-26-2009 05:04 PM
Teenage son?
http://www.hydroempire.com/store/index.php
RStephen 10-18-2010 11:45 PM
POWER COMPANY CORRUPTION.
Yes, it happens. I hope you are not in a "Cooperative" and you are where they regulate.
You can get a Kill o Watt EZ and test the appliances yourself to make sure there is nothing on your end. Document everything.
If you have a new digital meter, several "experts" have documented faulty installation causing high bills.
hyunelan2 10-19-2010 07:17 AM
Have your bills been "actual" reads or just "estimates?" Here, ComEd does no read the meter every month. They only read the meter like once every 3 months and issue "estimated" reads in-between. I have had the occasion where they underestimate the reads, then the actual read is high and I have a high bill to catch up.
fabrk8r 10-19-2010 08:05 AM
Do you happen to have a heat pump?
I had one case where the A-coil had a leak and the homeowner didn't realize it until they got a really high electric bill because the home was being heated by emergency heat for a month.
