Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-18-2011, 08:45 PM   #1
Unknown stains on concrete
I moved into a home that has a lot of different stains on the basment garage floor. The previous owner had no idea what caused them.
Some look like rust stain and it is definately in the shape of a tire thread, about 4x6 inches and there are five. The other stains look like various kinds of paint or stain spills and are different colors.
I have tried paint thinners--Acitone---lacquer--and strong industrial cleaners. I have also tried "lemon juice", amonia and muratic acid with very limited results.
I know this is a difficult question, especially not knowing what caused the stains, but I have tried everything I know. It is not oil stains, I cleaned them.
On all chemicals I tried, I used "scotchbrite pads" and a stainless wire brush.
Giles is offline   Reply With Quote
Old 04-19-2011, 07:33 AM   #2
for rust, try CLR(calcium/lime/rust solution). For paint, try a putty knife and/or paint remover.
Old 04-19-2011, 09:17 AM   #3
Rent a powerwasher and do the floor. Scrape off the globs first.
Ron
Old 04-19-2011, 09:43 AM   #4
Ron
I have used my power washer, there is no surface buildup to scrape. It is in the concrete. I have even tried four different paint removers. I think I will have to clean entire surface and apply a paint coating. Don't really want to do that
Old 04-19-2011, 11:31 AM   #5
You will need a sealer to keep the rust stains from bleeding through the paint.
Ron
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
