#1 |
unistrut+rust
which unistrut channel finish offers the best rust protection in an outdoor enviroment? stainless is too expensive.
i was thinking the perma gold because plateing is done after machining and cutting leaving no exposed edges. maybe rate pregalvinized,hot diped galvinized,perma gold,electroplated green painted in order of protection and longlivity? thanks |
#2 |
MarginallyQualified
unistrut+rust
rustoleum with primer
#3 |
unistrut+rust
I am an Engineer for Unistrut and would be glad to help. If cost is a concern and is keeping you from using stainless, you may want to consider hot dipped galvanized. Cost is higher than the Pre Galvanized or Green, but corrosion resistance is much better. We do, however, use the green and pre galvanized a lot even for outdoor applications. They are the most economically priced and perform well in the weather still.
I am not a big fan of the gold personally, others may or may not disagree. The pre galvanized and green are pretty similar to each other in corrosion resistance. If you have any other questions, do not hesitate to call me at our office 440-348-9450. My name is Matt. |
| Display Modes | |
| Steel studs rust basement help | bergerdude | Building & Construction | 16 | 11-04-2011 12:11 AM |
| Cleaning brush | StevenH | Painting | 19 | 02-06-2011 12:13 AM |
| Seeking advice on severe rust buildup issue. | YerDugliness | Plumbing | 2 | 05-07-2010 07:02 AM |
| bathroom sink rust removal? | bofusmosby | Plumbing | 4 | 11-12-2008 07:28 PM |
| fertilizer fleecing? | Wisco | Landscaping & Lawn Care | 3 | 08-24-2008 07:14 AM |
