Unique Wall Texture - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2007, 11:56 AM   #1
Unique Wall Texture
In my house, the walls have a unique texture that appears to have been made with a sea sponge. I have tried to duplicate it to no avail, using sponges, latex casts of the original, etc. I am using medium texture compound.
This is in the actual plater, and not done with paint.
Does anyone have any ideas on how to duplicate this? There are cracks in the wall I need to fix.
Also, could it be a brush that made the original texture?
Any help or ideas is appreciated!
Dan
dcarlton is offline   Reply With Quote
Old 07-28-2007, 10:27 PM   #2
remodeling pro
One of those problems with old plaster work. Every palsterer's textures were different, even the "standard" stomps and swirls depending on the condition of his individual tools. Some guys even made their own "special" items to set their work apart from the crowd. The only thing I have ever run across on a job that was even remotely like the picture had much more pronounced relief in it, but you may be able to soften that by using a thinner mix. We matched it with a technique recommended by a local paint supplier. Loosely crumple a couple of sheets of newspaper, then put them inside a typical thin plastic dry cleaning bag, roll a coat of mud on the surface, then use the bag to imprint it. It took a couple of tries to get the proper mud mix, and a feel for how hard to press the "tool", but the repairs blended in very well. Worth a try.
troubleseeker is offline   Reply With Quote
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
Removing Texture From Interior Wall JustWondering Remodeling 3 05-28-2007 06:56 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
