Unevenly Wiped Down Tile - Any Fixes? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 01:40 PM   #1
Exclamation
Unevenly wiped down tile - Any Fixes?
Hi Everyone! We just put new grout on our newly tiled shower wall. We were working on such a large area that by the time we got started wiping all of the excess grout down, it had hardened to the point where we had to scrub extra hard. This left uneven spots all over our wall Ė including some spots that go below the tops of the tiles. The grout is still fresh (though dry now) and we havenít touched it at all in 24 hours. The question is, can we just mix some more grout and lay it down directly on top of yesterdayís coat? Since we wiped everything down smoothly, will we have to roughen it up at all first? If you donít recommend laying another coat down on top of the original, will the grout be ok if itís only a little bit under the top of the tile? Thanks for your replies!
Stephen_Rachel is offline   Reply With Quote
Old 02-04-2008, 05:48 PM   #2
Rewards Points: 1,232
Either spray the wall with water or mix the grout a tad wet and fix the areas, no problem. The sooner the better.
Tscarborough is offline   Reply With Quote
Old 02-07-2008, 10:03 AM   #3
Thanks for your reply. I think we've waited too long at this point unfortunately, so we're going to just redo the areas we think are too thin. Good advice for our next tiling project though!
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
