Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-26-2011, 01:50 AM   #1
Understanding electrical specs...
I just bought a new (biggest name brand top of the line) chainsaw chain grinder that was advertised as having a:"Single phase, 115V-AC, 60 HZ, 3 amp, 285/300 watt, 3400 RPM direct-drive motor, 0.38 horsepower." but when I took the guard off, the motor had a sticker that reads: "4.2A 200W 115V 60Hz 3400rpm motor."
Did I get a much weaker motor than advertised???
lodestar is offline   Reply With Quote
Old 11-26-2011, 02:25 AM   #2
JOATMON
ddawg16's Avatar
This is where knowing your electrial math helps....
Watts is voltage times current.....
So, if it's a 3A motor.....@ 120Vac, then that would be 360 Watts
Hmmmmm....that does not match......
Ok.....lets look at the 4.2A @ 115Vac...so, 4.2 x 115 = 483 watts.......
Oh boy....not very close to 200w......'
Did you get a weaker motor? Based on the above #s', I would say you got a Chinese motor....Weaker? Well..........maybe it was lost in translation....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-26-2011, 11:09 AM   #3
Civil Engineer
When computing the HP of a motor, you have to account for efficiency and startup issues. In your case, the original specs state that the motor draws 3A, which could mean that at full load, the motor draws 3*120 = 360 watts. This is not the actual available power, which is always going to be less due to efficiency losses, so the actual available power may be close to 285/300 watts as shown.
The numbers on the actual motor don't make a lot of sense. However, when sharpening a chainsaw blade, you don't need a lot of power, you need a tool which has a sharp file of the proper size, accurate adjustments for the various angles, and a good grip on the bar. Too much power will ruin the blade quickly. I sharpen mine using a clamp on, hand drawn system that works very nicely.
Old 11-26-2011, 11:33 AM   #4
That's why I asked, I ran the math on an online calculator and the numbers didn't make sense to me (they still don't). The grinder is made in Italy, but the motor in Guangdong...
I just got the grinder and haven't run it yet (snow on the ground gas in the small shop I have). So I was just setting it up and wondering as to the difference in advertising/reality?
Thanks. I guess it comes down to whether I want to believe the Wattage figures or the amperage @ voltage figures.
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
