Ugly Steps - Thoughts? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 08:48 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Ugly steps - thoughts?
I have 2 steps that step up from my garage into the laundry room/mudroom (laundry going to be relocated) that enters the house. They are just some OSB steps that it looks like the builder put in and the previous owner left there. They look ugly, temporary, and out of place.
What should I do with them? Peel-&-stick, paint, replace with something else?
Attached picture:
hyunelan2 is offline   Reply With Quote
Old 10-20-2010, 09:22 AM   #2
jlhaslip's Avatar
Rewards Points: 2,132
First of all, they need nosings.... 3/4" minimum to 1 1/4" max.
Then cover the ugly OSB with lino or stick-down vinyl tiles at minimum.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-20-2010, 09:49 AM   #3
Custom User Title
Rewards Points: 252
I'd wrap the riser with something like this: http://www.lowes.com/pd_17656-1487-7...%3FNtt%3Dtread
I'd probably use a cheap 1x if you are going to just paint it.
Then I'd use something like this for the tread: http://www.lowes.com/pd_326988-1487-...%3FNtt%3Dtread
Again, I'd find a cheaper paint grade one so it can be painted.
no1hustler is offline   Reply With Quote
Old 10-21-2010, 03:48 PM   #4
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Why not just tile them? dorf dude.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following User Says Thank You to shumakerscott For This Useful Post:
BigJim (10-21-2010)
Old 10-21-2010, 04:20 PM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Leave a big empty box near the stairs and pick it up each time you need to use the stairs. You;ll never even see the, Just be careful that you don't trip.
WirelessG is offline   Reply With Quote
Old 10-27-2010, 08:06 PM   #6
Rewards Points: 150
they make a laminate tile, that goes down the same as laminate wood floors, you just put down an underlayment and snap the tile into place (it floats), Then you grout between with the grout especially for the laminate tile. Is inexpensive and sold at most home improvement stores.
guest is offline   Reply With Quote
Old 10-30-2010, 08:51 AM   #7
Indoor/outdoor carpeting.
JohnJak is offline   Reply With Quote
Old 10-30-2010, 08:57 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
If they were mine I would take the wood up and pour some stained or stamped concrete for steps.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 08:32 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
Brick steps failing sk8z Building & Construction 10 03-28-2009 03:16 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
