Ugly Driveway - Need Good, Cheap Fix - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 03:19 PM   #1
House was built in 1978, and I believe it's the original driveway. It's pitted here and there, and is discolored in shades of grey and rust all over.
I called some concrete companies for resurfacing and heard estimates around $2000. I looked up staining (thinking that an all-over stain would help) and got only slightly lower. I read about painting and that seemed to be a bad idea.
Will professional cleaning help get up the stains? How much should I expect to pay for an average sized two car driveway? Any other ideas of what I can do? I really can't spend more than a couple hundred bucks, but it's such an eyesore that I need to do SOMETHING.
Thanks!
fixitmama is offline   Reply With Quote
Old 04-18-2011, 05:46 PM   #2
Rewards Points: 150
Can't help with the pitting, but this stuff removed rust stains (from iron in well water) from our asphalt driveway. It will probably take more than one jug.
http://ecx.images-amazon.com/images/I/41z4BFMS8LL._SL500_AA300_.jpg
Could the gray stains be mold or mildew? If so chlorine bleach may help.
NancyNGA is offline   Reply With Quote
Old 04-19-2011, 08:22 AM   #3
Rewards Points: 5,336
Post some photos.
Ron
Old 04-21-2011, 02:41 AM   #4
I don't know about this, But if you want to know then post your problem in detail, Post here some pictures here. It'will be very helpful for me to give you answer. So keep try to post here in detail.
Phoenix Homes for Sale
Makenna is offline   Reply With Quote
Old 04-21-2011, 05:09 AM   #5
NACE Coating Inspector
mustangmike3789's Avatar
Surecrete Design Products has a product called Broom Coat. It goes on at less than 1/8". This is an easy and cheap fix but i dont think a couple of hundred bucks will get you very far on a two car driveway even if you were to use a concrete stain. i think that Quick Crete makes a product like this too. call some pool builders or paint stores to get some contacts for some deck guys. acrylic concrete coatings can range from $2.00/sqft and up. you can stain it yourself and save on the labor cost, you will need two coats and i dont think that a couple of hundred will be enough. do not use paint, it can not handle foot traffic or hot tires.
mustangmike3789 is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Asphalt Driveway erb170 Building & Construction 7 10-24-2011 05:22 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
Spreading cement over asphalt driveway? Dagz Building & Construction 1 09-06-2010 07:55 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 11:02 AM
