Tuck Pointing Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-19-2007, 02:47 PM   #1
Question
Tuck pointing help
I have a 1950s era brick house that is in need of some minor tuck pointing on the the rear and side of the home around a few windows and the chimney.
I have a family friend who is going to do the work for me and has asked if I would like him to use masonry mortar or masonry-colored vulkem caulk.
His rationale for using the vulkem is that the cracks are caused by the house settlings and are likely to continue shifting as the house settles over time. With the vulkem the cracks would not re-occur as the caulk will flex with the surrounding bricks delaying the need to do the work again in a few years.
Is this a valid rationale? Anyone have recommendations/experiences with this that they can pass on?
Captcha is offline   Reply With Quote
Old 11-19-2007, 03:13 PM   #2
concretemasonry's Avatar
Rewards Points: 2,640
Beware of any family friend if he suggests using any caulk.
He may not be a "friend" in the future, but he will always be "family".
Any minor repairs on a 50+ year old home are probably due to deterioration from the initial settlement and shrinkage, so any cracks are probably "dead".
Once you start with some caulk junk, you are stuck with it forever. Tuck point minor spots on a 50 year old veneer does not suggest a major problem, but a restoration to original.
concretemasonry is offline   Reply With Quote
Old 11-19-2007, 05:54 PM   #3
Eibwen
Go with mortar for alll of the reasons CM suggests.. Plus it will match the current alot better with a little aging.
Sammy is offline   Reply With Quote
Old 11-20-2007, 06:17 AM   #4
so-elitecrete
Rewards Points: 150
they're right,,, NEVER CAULK BRICK
more'n likely, your home's got modern cement mortar rather'n older lime / sand mortar which was much more flexible & forgiving to old brick,,, vulkem does have some good mtls but not for this work.
so-elitecrete is offline   Reply With Quote
