Tub & Tile Caulking - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-23-2006, 07:26 PM   #1
rdp
Rewards Points: 87
Tub & Tile Caulking
After applying a bead of caulk around the top of my tub ... and then smoothing the surface of the bead [caulk] with the tip of my finger ... there always seems to be some additional cleanup necessary.
This cleanup can be frustrating at times and I wonder if you have suggestions to make that job easier. What about waiting for the caulk to dry and set up .... and then trimming up the excess with a razor?
Tricks? Tips?
powrus is offline   Reply With Quote
Old 11-23-2006, 08:53 PM   #2
general contractor
I always use a slightly damp washcloth to spread the caulk instead of my finger. This provides a nice smooth finish and keps the caulk on the surface and off of me.
cssconstruct is offline   Reply With Quote
Old 11-23-2006, 09:29 PM   #3
One reason the pros make it seem so easy is that they do it often. They know how much to squeeze out of the tube or gun before they attempt to smooth it. I like to start with a little less of a bead of caulk than I think I need. Then I use a spoon dipped in water to smooth it. If you keep the spoon at the same angle, the bead will be consistant all the way around the surface. Try squeezing about a 2" bead out and smooth it. If it is too much, reduce the amount and try again.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-24-2006, 05:15 AM   #4
rdp
Rewards Points: 87
Thanks for the feedback on caulking. Both great ideas.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
