Trying To Understand Insulation For My Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 07:06 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Trying to understand insulation for my basement
I am still in the design/planning stages of my basement. I will be finishing off right around 1100sqft, which is just unfinished at the moment. Maybe my question is dumb and I am missing some point - but it has to do with R values.
I am debating which way to go: the foam/poly panels attached to the concrete, then framing; or frame 1" off the wall, use a plastic vapor barrier, and put in batts of insulation.
The insulated panels have low R-values, like this one that has a R value of 5.
Being only a 5, will I get better insulating results just putting in batts of R-13 fiberglass, no? If this is true, why does anyone bother with foam at all if the fiberglass bats are better insulation at lower price per sqft? Or do people use a combination of the two?
P.S. I live outside the Chicago area, my basement has no moisture issues, the concrete has been cured 8 years.
hyunelan2 is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
