-   -   Trying to remove flush mount finish nails (http://www.diychatroom.com/f2/trying-remove-flush-mount-finish-nails-98223/)
pms1228 03-13-2011 01:08 PM
I am trying to remove an overhead kitchen cabinet however the installer nailed it to the frame of the cabinet on the right. The cabinet I am trying to remove is deeper than the other cabinet so the finish nails are in the middle of the cabinet wall that I am trying to remove.
I need to remove this cabinet so I can trim it to accommodate a refrigerator that is taller than the opening.
Can anyone suggest a way I can remove these trim nails? It is a small space to work in. I thought I could use a tap and drive the nail all the way throught the cabinet wall but its a struggle to try to work inside of the cabinet.
I was wondering if I could use a drill to force the finish nail through the cabinet wall.
Thanks for your help!
Paula
Ron6519 03-13-2011 03:05 PM
Paula
There is usually room between the cabinets on the top and bottom. Place shims between them and drive them up from the bottom and down from the top. You should see the frames separate. Continue until you can fit in a metal blade and cut the nails.
Remove the fasteners in the cabinet back first.
Ron
pms1228 03-13-2011 03:13 PM
trying to remove flush mount finish nails
there appears to be a very little space at the top but the bottom of the 2 cabinets are really tight. the only kind of shim i know about is wood and it would not fit between the space. is there a shim that has a very thin starting edge? (sorry i'm new at this.)
pms1228 03-13-2011 03:14 PM
Ron6519 03-13-2011 03:28 PM
Then just start at the top. As you do, the face frames will separate and you'll be able to tap in shims from the front.
Then do sell plastic shims that resemble wood ones. I just bought a package at the local Big box store.
Ron
rubberhead 03-13-2011 08:49 PM
I agree with trying to seperate the cabinets enough to cut the nails. You can start to pry them apart with a painters tool: http://www.kk.org/cooltools/5-1-painter-tool.jpg
And then use a hacksaw blade to cut the nails. You should only have to spread them about 1/16th".
amen2u 03-13-2011 09:10 PM
. . . or try a cat's paw. They have a very thin leading edge and are strong.
rubberhead 03-13-2011 10:06 PM
I assume the OP is trying to do this without destroying the trim work. A cat's paw will make a big mess trying to remove those small nails.:eek:
Jay 78 03-13-2011 10:25 PM
As Ron said, there are alternatives.
I just saw some "composite" shims for the first time at Home Depot yesterday, and they were less than $2. Going to pick some up next time. Perhaps the thin edge could be hammered even thinner?
amen2u 03-14-2011 08:30 AM
Just to clarify, the cat's paw is to initiate a separation for the shims to be introduced.
Besides, my dad always told me it was the workman and not just the tool the caused the mess.
dtsman 03-14-2011 08:33 AM
Use a nail punch and hammer the nails all the way in until it clears the wall. Now you will only have small round holes that may or may not be noticeable when you reinstall it. If it pops out on the other side, cut it with a pair of heavy diagonal cutters or something.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
Ron6519 03-14-2011 03:03 PM
My Dad said, "Use the right tool for the right job".
Ron
Mr Chips 03-14-2011 03:30 PM
I think amen2u was reffering to one of those combination bars, with a prybar on one end and paw on the other, and not a traditional cat's paw
http://www.garrettwade.com/images/500/59T0101.jpg
Ron6519 03-14-2011 05:58 PM
That's a pretty good talent.
What am I thinking now?
Ron
rubberhead 03-14-2011 09:40 PM
Bo
Remember,
(Red Green)
I'd be worried about splitting the trim by driving the head through all the way. I may have missed this info, but was it ever stated as to how wide this trim is? Driving a nail through an inch of material can easily split the material. Just my experience anyway. :thumbup:
