Trying To Clamp A Monitor Arm To A Desk With Small Edges - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 01:05 PM   #1
Trying to clamp a monitor arm to a desk with small edges
Hi, I have a Monitor arm that needs about 2-3" of surface area in order to clamp well. Trouble is the sides of my desk only extend about 1" out. Is there any way I could get a good clamp on my desk, or is the only option to get a new one?
Delta223 is offline   Reply With Quote
Old 10-07-2013, 09:26 PM   #2
Rewards Points: 220
pic/s ......
Fix'n it is offline   Reply With Quote
Old 10-07-2013, 10:16 PM   #3
Rewards Points: 6,652
Originally Posted by Fix'n it View Post
pic/s ......
Of what, the sky? You do not need pictures, for what they are describing. I fully understand from their description what the problem is.
Old 10-07-2013, 10:19 PM   #4
Delta223, if this is a desk at home, I would just take a board and use Carpenter's nails to adhere it to the surface, then use the clamp to attach to that. For even better security, to make sure that the board does not come loose, attach with bolts through the board, through the desk, held in place with nuts underneath.
If it is a work desk, you are pretty much SOL, unless you can find a weighted base that you can attach the flatscreen arm to.
The Following User Says Thank You to gregzoll For This Useful Post:
Delta223 (10-08-2013)
Old 10-07-2013, 11:08 PM   #5
Rewards Points: 220
Originally Posted by gregzoll View Post
Of what, the sky?
yeah, the sky. whats it to ya ?
Old 10-08-2013, 06:46 AM   #6
From what is the side of the desk made? How hard or destructive would it be to cut an opening in the back to provide the clamp additional surface area?
oberkc is offline   Reply With Quote
Old 10-08-2013, 12:01 PM   #7
Hi, the top is wood, the sides are metal. Unfortunately it is not my desk so I may only make minor fixes to it.
Old 10-08-2013, 12:44 PM   #8
If unable to drill/cut/screw, then the best I can think of would be to clamp a board to the metal back, and attach a small "shelf" to that board, adjacent to, or above, the desktop surface. Clamp the monitor stand to the shelf.
The Following User Says Thank You to oberkc For This Useful Post:
Sand down edges of drywall patch panel for tape? patchtaper Drywall & Plaster 2 12-15-2012 10:53 PM
What is standard height for recessed light above a desk? andmmy Electrical 2 06-15-2009 07:21 PM
Old flip top school desk Zarack Carpentry 15 09-09-2008 10:57 PM
