Trouble Drilling Into Studs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 02:16 PM   #1
Hello All,
It's my first time here, so hopefully I'm putting this question in the right place!
In short, I'm having trouble drilling into studs. My girlfriend just moved into a new apartment in a high rise building and I was mounting her TV on her wall. I used a stud finder to locate a stud and an 18v cordless drill to drill into it. I was using a drill bit slightly smaller than the mounting screws to pre-drill a hole, but once I got through the drywall, the drill bit wouldn't go any further. I drilled in 2 spots about 12 inches apart and I had the same problem. Has anyone here faced the same problem and is there an easy way to fix it?
tillhouse is offline   Reply With Quote
Old 06-07-2012, 02:19 PM   #2
Probably metal studs
RYANINMICHIGAN is offline   Reply With Quote
Old 06-07-2012, 02:52 PM   #3
47_47's Avatar
Rewards Points: 50
You could also be hitting plumbing drain/ vent or supply line. Is there a bathroom or kitchen or the other side of this wall?
47_47 is offline   Reply With Quote
Old 06-07-2012, 03:18 PM   #4
Rewards Points: 150
when you said high rise apartment I was instantly thinking of metal studs as well. I would try to find a stud on another wall and "test" it too. If you can't make it into that one either its probably metal studs.
Have any large magnets?
knotquiteawake is offline   Reply With Quote
Old 06-07-2012, 03:20 PM   #5
Newbie Bill
Rewards Points: 520
When I heard Hi rise apartment, I'm thinking concrete.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
jbfan (06-07-2012)
Old 06-07-2012, 03:24 PM   #6
The thought occurred to me that it might be metal studs - I'm going to check with the building management to see if this is true. If they are metal studs, any suggestions on how I might attach a TV mount to the wall?
As for the wall itself - no, it's not adjacent to the bathroom or the kitchen. It's a bedroom wall that is adjacent to the living room, so it seems unlikely that there are drain pipes passing through there.
Old 06-07-2012, 03:55 PM   #7
MarginallyQualified
Rewards Points: 2,464
Yes; drop back ten and call the management or LANDLORD
Ask them the what and how
Odds are they'll do something for you rather than have to repair later
Old 06-08-2012, 10:08 AM   #8
Rewards Points: 1,452
Sounds like concrete. You can tap into the holes you made with a nail and see if you hear metal.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
drtbk4ever (06-08-2012)
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
Drilling through metal studs plus4dbu Building & Construction 6 01-24-2009 08:37 PM
Attaching Studs to Concrete/Which way mjkpainting Carpentry 17 12-30-2008 10:02 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
