Trex Deck Installed By A Contractor , Needs To Be Pulled Up - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 06:48 PM   #1
Trex Deck installed by a contractor , needs to be pulled up
We had a Trex Deck installed by a contractor but he did not leave spaces between the boards. There is some board buckling and build up of dirt, algae on the boards as a result. We have asked him to address this and he is willing to take the boards up, replace the buckled ones and reinstall with spacing. The question is..will this compromise the integrity of the Trex to be rescrewed down a second time?
rboy is offline   Reply With Quote
Old 06-15-2010, 07:49 PM   #2
I installed a lot of trex in my college landscaping days and am baffled to how someone could screw up the spacing... a warning label is stapled to every board.
Did the contractor burry the screw heads into the decking or can you still see the heads? Did you use a hidden fasteners system?
If the heads are buried into the trex from above, chances are that the trex will tearout when he tries to back the screws (even if he used the proper screws, which most people don’t). It will probably look like crap.
If you can still see the screw heads, of if he fastened from underneath you should be in luck.
To minimize damage, try to get him to work on a hot day.
Good luck...
Eric J is offline   Reply With Quote
Old 06-18-2010, 03:40 PM   #3
Framing Contractor
He will have to pull every board up since he didn't space any. He can't just pull up the buckled ones and space those because he will have no room to space. It's only a matter of time before they all buckle.
Joe Carola
Joe Carola is offline   Reply With Quote
general questions re: Trex Deck Billnjude General DIY Discussions 5 10-30-2009 06:32 PM
Trex deck cracking and flaking wallace32 General DIY Discussions 41 06-11-2009 10:22 AM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
