Trex Deck - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 05:08 PM   #1
Trex Deck
We were among the first to install a trex deck (15x40) approx. 8 yrs ago. We noticed from the beginning the discoloration. We gone through a white liquid cleaner Trex recommended bleaching many times and we are back at square one. Same moldy, spotted gray deck. We have mixed feeling about using a stain.
Are there any solutions? I've noted this is a very common problem. Has Trex addressed this issue.
Solly
Solly is offline   Reply With Quote
Old 06-05-2012, 08:32 PM   #2
robertcdf's Avatar
Most of the people on this board will just say "Should have used real wood to begin with" and other such things. However the composites of today (well, the good quality ones) are MILES better than the early composite products. I Like Fiberon Horizon, and Dura Life decking. Trex also has an improved product called Transcend that is ok but is usually more expensive than the other 2.
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
Solly (06-06-2012)
Old 06-21-2012, 10:26 PM   #3
There is only one way to fix the problem with mold or mildew in Trex. Use New Image Coatings Mold Eliminator as directed on the container to clean and even out the color. And then use Seal-Once Multi-Surface Waterproofer as directed with 2 wet on wet coats. The waterproofer will keep the mold and mildew from growing again as it needs moisture to grow.
Paint Guru is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Trex LED deck lighting bmoney69 Electrical 7 04-16-2012 10:12 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
