Trenching Underwater? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 05:31 PM   #1
zyx
trenching underwater?
I am digging a 2' trench for power and water. There's 20' or 30' section that is below the water table . . . in fact, the water table is pretty much at the soil surface level. I've been working on it with a trenching shovel, but its getting pretty much impossible to make any progress in the muck. Any ideas? Thanks!
zyx is offline   Reply With Quote
Old 01-21-2013, 05:41 PM   #2
Rewards Points: 13,740
Dig a pit off to the side deeper then the trench and use a mud pump to pump the water away from the area.
Old 01-21-2013, 05:47 PM   #3
Rewards Points: 258
tempory walls to hold back the sides while you dig, then remove after you are done laying the lines.
edit: mud pump, while you work....
just my 2cents
redman88 is offline   Reply With Quote
Old 01-21-2013, 06:55 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,.... Underwater, with the mud pump, ya may not even need the shovel....
Bondo is online now   Reply With Quote
Old 01-21-2013, 07:19 PM   #5
Rewards Points: 6,652
Water level at the top of the soil, what are you doing, trenching in a pond or wetland?
Tags
trech , trenching , water
Wire suitable for underwater usage 7.62 Electrical 24 04-20-2012 09:06 AM
Underwater Room HFerrari13 Building & Construction 33 12-10-2011 04:23 AM
trenching near buried electric cable rizzo Landscaping & Lawn Care 9 04-22-2009 07:24 PM
underwater elec. panel robin power Electrical 33 11-02-2008 04:38 PM
Underwater pump knocks out GFIC switch Ronnie1a Electrical 6 08-28-2008 12:14 PM
