Tree Fell On House-broke One Rafter - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 12:22 PM   #1
Tree fell on house-broke one rafter
Neighbor was cutting his trees down and one BIG section of his poplar fell on the center of our house. We have an older home and the rafters are on 24" centers. The tree fell parallel with the rafters. The rafter that it hit had two large knots. The rafters are 2x6 by 16'. The largest knot was pretty much centered and it broke out leaving a large horizontal centered crack that extends both directions approximately 4 foot each way. Question is how do we best fix this? Do we put a scab on both sides the full length and how much past the end of each crack? Also should we put in upright supports at the end of each scab? What type of material should the scab be?
rookie1234 is offline   Reply With Quote
Old 04-07-2009, 12:26 PM   #2
You call a Pro to fix it & your neighbors insurance pays for it
I'd put another rafter in full length & attach it securely to the other rafter. Make sure there isn't any hidden damage caused by the tree. Also make sure the roof is intact & will not allow water in to cause further damage. I'd also use a 2x8 if I can get it in there
If you can't get a 16' in there (prob not)
Then go with as long as you can
You may need to jack it up slightly
Be careful of waht you se to jack it up - support below
If possible an upright would help
But again it needs a supporting wall underneath
Old 04-07-2009, 02:02 PM   #3
Concrete & Masonry
Rewards Points: 470
I agree with Dave's first statement, that's what insurance is for.
jomama45 is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Termite exetermination tenting house. gante Pest Control 11 07-18-2010 11:44 AM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 05:05 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
My new beautiful house is falling apart!!! DonnaS Building & Construction 6 05-06-2006 04:30 PM
