Treated Decking Over Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 03:20 PM   #1
Treated decking over concrete
Hey guys, I have a concrete porch on the front of my home and i would like to cover it with treated decking. Can the wood go directly over the concrete or should I use a space to raise it? if so what should I use for a spacer? Thanks for any help!
hazky is offline   Reply With Quote
Old 04-29-2013, 04:08 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,010
I can be laid directly overtop but I would always prefer to see a vented space and/or some sort of capillary break between the two.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 04-29-2013, 06:58 PM   #3
Rewards Points: 4,534
me, too,,, what windows said migvht also consider cutting some grooves in the conc to drain away any wtr that gets underneath
Old 04-29-2013, 09:46 PM   #4
Rewards Points: 20
I'm about to do the same project. I'm going to build it a few inches above the concrete for a little breathing room.
hotkarl is offline   Reply With Quote
Old 04-29-2013, 09:53 PM   #5
i am doing this also- i have zero room to raise. i'm thinking about sealing the concrete with a concrete sealer- should i bother?
rissa is offline   Reply With Quote
Concrete Patio Enclose with Pressure Treated Wood ryanb4614 Concrete, Stone & Masonry 8 04-23-2012 07:22 AM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 09:46 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 07:16 PM
decking over concrete without posts hotvw Flooring 2 11-11-2009 10:41 PM
Wood decking over concrete stoop? spaceman spif Carpentry 2 10-24-2009 12:45 AM
