Are Trap Primers Required In Residential? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 06:02 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Are trap primers required in residential?
My brother is building a new home and yesterday he had the inspection for a Certificate of Occupancy. He has a floor drain in the basement that takes the condensate from the AC unit. The inspector commented he did not have a trap primer but did mot write it up.
Question; Is a trap primer required by code in new residential construction?(House is in South Carolina).
Coastal South Carolina
Old 04-04-2014, 06:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 564
I am not required to use one on a drain with ac. The condensation is suficient.
The Following User Says Thank You to TheEplumber For This Useful Post:
rjniles (04-04-2014)
Old 04-04-2014, 06:39 PM   #3
Plumber
Rewards Points: 564
Here's a follow up rj-
Per UPC 1007.0: Floor drains or similar traps directly connected to the drainage system and subject to infrequent use shall be protected with a trap primer, except where not deemed necessary for safety or sanitation by the Authority Having Jurisdiction.
I don't know which code is used in SC
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
How to connect a trap primers for a hot water tank Ballastar Plumbing 5 02-25-2010 12:38 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 08:14 AM
