Tractor Seat Spring Modification - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 11:14 PM   #1
Talking
I bought a large lawn Tractor some time ago and the previous owner installed a custom seat with "leaf Springs" The springs set the seat too high and I was wondering what damage would be done if I were to heat the springs ---in a small section---and compress the seat in a lower position.
I am guessing this would ruin the springs but would like some opinions
I have NO IDEA how this got posted here--should have been a new topic--I know it's my fault --How do I move it??
Giles is offline   Reply With Quote
Old 03-12-2011, 05:08 AM   #2
An old Tradesmen
Rewards Points: 6,876
Moved it to general for you.
The Following User Says Thank You to beenthere For This Useful Post:
Giles (03-12-2011)
Old 03-12-2011, 12:12 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
got any pics of this Giles?
Springs, to remain springy, are tempered. If you heat a spring, you will soften the metal and it will lose it's resiliency. Since this is a seat that doesn't hold over 300 pounds (and most likely a lot less), anything you do becomes less critical. As such, if is often possible to heat a spring in a particular spot to allow that one part to collapse as long as you do not allow the softening spread to an area that would cause too much collapse and as such, total loss of the springs springiness.
So, if you could post some pics, it would help give you some direction as to where you might be able to collapse the spring without losing all of it's use as a spring.
Old 03-15-2011, 07:29 AM   #4
Heating would be bad, if there are a set of leaf spring then take some out. Usually there are a set of five or so depending on the weight to be carried. A picture would help us, help you.
screwy is offline   Reply With Quote
Think Spring! LateralConcepts Landscaping & Lawn Care 0 03-09-2011 10:46 AM
Size of Garage Door Torsion Spring planet Carpentry 3 12-19-2010 03:29 PM
Draining a natural spring in a yard ? otrgeno Landscaping & Lawn Care 1 04-01-2010 07:22 PM
Trane Aux heat modification tj1mcd HVAC 2 12-05-2009 07:24 PM
Spring Hinges jb198606 General DIY Discussions 3 02-06-2006 08:40 PM
