I am assuming a two-stage snowblower. If it is not throwing snow from the 2nd stage, I would guess that the sheer pin in the auger has broken. Designed to do such when severly overloaded or picking up limbs, etc. Check your owners manual, should be a fairly easy fix.
Is it Running... Couldn't resist. No but not really much to go on here. If it a 2 stage unit. If so are both stages spinning. Do you here any noises that seem abnormal (like a belt slipping).
I am guessing but not sure on your statement that you have a two stage and for some reason the second stage blower is not working properly.
I would recommend posting your model or any other info you might have so others can respond informatively on your particular unit.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
