Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-09-2007, 03:31 PM   #1
hwm
Toro 521 electric starter repair
Does anyone have step-by-step instructions for repairing the electric start motor on a Toro 521 Snowblower. It does not engage the flywheel when the starter button is depressed. I've removed it, soaked the shaft in WD40. The gear will move up and down the shaft by hand, but I understand it is supposed to snap back once released, which it does not do. Is this a DIY fix or do I need to take it somewhere. If so where?
hwm is offline   Reply With Quote
Old 12-11-2007, 07:22 PM   #2
Can you post a photo?
redline is offline   Reply With Quote
Old 12-12-2007, 12:05 AM   #3
hwm
Working on it. It's a simple arrangement, an electric motor that bolts onto the side of the blower. The shaft has a heavy gear that can slide back and forth on the shaft with a spring around the shaft between it and the motor. The gear engages the flywheel at one point and I think pushed down the shaft and disengaged by centrifigal force when the engine catches.
Old 12-12-2007, 07:21 AM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,.....
The odds are the Bendix Drive is worn out,+ you need a New starter.......
Old 12-12-2007, 10:28 PM   #5
hwm
Since I've used it about 10 times, it may have rotted out, but I doubt it wore out. Would disuse cause the failure? If so, I'll just pull start the damn thing. It would make no sense to get another one just to have the same thing happen. It sure is nice to have on sub-zero days and tough conditions, so I'd rather fix it.
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
CertainTeed starter shingle ? MACCC Roofing 2 04-20-2007 03:26 PM
