Toro 421 Snowblower Transmission Stopped Engaging - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 02:46 PM   #1
Toro 421 Snowblower transmission stopped engaging
I have a Toro 421 snowblower. (4 cycle - gas & oil separate) Was running fine. I disengaged the forward drive handle, the unit stopped, but would not start the forward movement again when I engaged the handle. Auger was not affected, just the drive forward and backward. Can anyone tell me where to start troubleshooting this?
Thanks for reading!
jmr4pyro is offline   Reply With Quote
Old 01-18-2011, 08:49 PM   #2
Rewards Points: 5,336
Broken drive belt?
You need to understand the drive system of your unit. Try downloading the service manual.
Ron
Old 01-18-2011, 10:24 PM   #3
A Little Of Everything
Rewards Points: 1,364
Thanks for reading!
When you pull the drive lever, do you have tension? Or is it limp like it's not connected to anything? If that's the case, it could be anything from a broken spring to a broken connecting rod.
Ron is right, though. Most likely it's a drive belt. But - in addition to that - you need a fundamental understanding of how the drive system works. (Honestly, it's not that complicated.)
It's going to be VERY hard for any of us to diagnose it from a distance without more information.
DrHicks is offline   Reply With Quote
Tags
snowblower , toro , toro 421
Need help - old Toro 7/24 snowblower Ottawa Landscaping & Lawn Care 3 12-08-2010 09:19 PM
does anyone know how to replace toro 924 snowblower shear pin? tgomar Landscaping & Lawn Care 4 03-23-2009 01:53 PM
Toro 7/24 Snowblower - friction wheel Ottawa Landscaping & Lawn Care 1 02-02-2009 08:01 AM
Toro snowblower adjustments Tom Fraser General DIY Discussions 1 01-03-2009 06:04 PM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 12:27 PM
