Torch-Down Plywood - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 03:34 PM   #1
Torch-Down Plywood
Is there plywood made of torch-down material and if so- I am looking to get a price for a 4'X8' sheet of 3/4" if this exists. Thank you!
Cazin is offline   Reply With Quote
Old 03-20-2012, 03:46 PM   #2
Rewards Points: 3,130
What in the world is "torch-down" material??? Never heard of it. Are you located outside of the USA?
The Following User Says Thank You to md2lgyk For This Useful Post:
Hardway (03-20-2012)
Old 03-20-2012, 04:18 PM   #3
I figured it out he wants to use plywood instead of fiberglass sheet to lay the torch down membrane roofing.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
I am not an expert and don’t claim to be, these are just my views and opinions.
Hardway is offline   Reply With Quote
Old 03-20-2012, 06:32 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
no there is not a plywood that is torched down
woodworkbykirk is offline   Reply With Quote
Old 03-20-2012, 06:44 PM   #5
I don’t have any first hand knowledge of this subject, but thought that there would not be any plywood used for this purpose. Because of the applied open flame.
Old 03-20-2012, 09:27 PM   #6
Rewards Points: 1,092
I used torch-down material on my deck. Solid plywood. As far as I know, that is the way it is done routinely. You heat the material, not the substrate, so I see no problem w/ wood.
Old 03-20-2012, 09:38 PM   #7
Rewards Points: 13,450
What is it your really trying to do with this plywood?
And I agree there's just no such thing as torched down plywood.
There's torched down roofing but only a fool DIY would try and do it, unless your looking to burn the house down get a pro roofing company with lots of insurance to do this one.
Old 03-20-2012, 09:58 PM   #8
So I guess I'm a fool. Huh. And all these years I thought I was a pretty savvy individual. The stuff you learn on forums is amazing.
Old 03-20-2012, 10:01 PM   #9
I'm hoping some of the roofers on here will post some of the pictures again of the roofs on fire from someone trying to do a torched down roof.
Old 03-20-2012, 10:06 PM   #10
http://www.prolineroofing.com/old_website/News2.htm
Torch down info sjacobso Roofing/Siding 8 07-24-2012 02:54 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 08:39 PM
