Tongue And Groove Siding Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 02:11 PM   #1
tongue and groove siding repair
How is tongue and groove cedar siding repaired when only a few boards are bad?
tmills@handypro is offline   Reply With Quote
Old 07-28-2012, 02:40 PM   #2
kwikfishron's Avatar
Rewards Points: 1,008
Welcome to the forum.
If it’s in the middle of the wall you’d have to cut off the back side of the groove on the last piece and face nail.
Posting pictures here go a long way to getting more detailed answers to you’re particular situation. How to attach a photo to a post
kwikfishron is online now   Reply With Quote
Old 07-29-2012, 10:39 AM   #3
Haverhill Trade 1965
If you can replace 2 pieces you can set them in a V, the point of V being the center joint, groove to tongue on one side, tongue to groove on the other, push in on the center and they should snap in. You can face nail at an angle through the tongue edge. Even better if it is bevel edge.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
mae-ling (07-29-2012)
Old 07-29-2012, 04:29 PM   #4
If your're lucky...That's a tough one to pull off damage free.
Old 07-30-2012, 07:00 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
Start by cutting a rip down the center of a piece that needs changing, if it is still to tight to pull after a center rip cut, then make another cut a 1/2 inch from the first cut then pull the little 1/2" piece out. this will allow you to extract the piece of siding without damaging good pieces on either side of it. To put the new piece back rip the back half of the groove off leaving the front groove in place. Approach the replacement area and with the siding on an angle pivoted outward at the bottom with the tongue facing upward slide the new siding up into the groove on the piece above and then face nail and or glue the replacement piece.
if you have a section of pieces that need changing then reinstall them like normal while leaving the ripped back cut for the top and last piece ..
hand drive is offline   Reply With Quote
Old 07-30-2012, 08:51 PM   #6
The only problem I ever had, (using the same method with oak flooring), was having to bevel the back side of the groove to relieve the pressure so it snaps in easier. If someone wants a job done a certain way, can't isn't an option. It just requires a little imagination. It's putting pieces in without taking out a whole row that's tricky.
How to repair tongue and groove that is subfloor cosmicblu Flooring 1 08-19-2011 05:12 PM
Refinishing Cedar tongue and groove siding cnda17 Carpentry 2 06-05-2011 01:17 PM
installing interior tongue and groove wood siding freemike11 Carpentry 1 05-10-2011 09:00 PM
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 06:07 PM
