Tongue And Groove Plank Instead Of Sheetrock Wall Covering? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 06:10 AM   #16
Rewards Points: 91
i think this is likely the cheapest way..................
gwilkrrs is offline   Reply With Quote
Old 12-11-2012, 07:42 AM   #17
joed's Avatar
Rewards Points: 13,324
Is drywall not required for fire protection especially if you use plastic vapour barrier?
Old 12-11-2012, 08:23 AM   #18
Roofmaster
Rewards Points: 2,210
Fire Barrier
Im not sure about the drywall fo fire barrier, but if the whole inside is T&G wood it is combustible. Maybe the studs do have to be covered with drywall to assure their integrity against collapse for a certain amount of time, though. I would not in any case rely on adhesive to a paper faced gypsum board or fastening to it. If you need the gyp, I would put it over the VB, then install the horizontal furring, then the T&G. Maybe a code official can ring in here.
Old 12-11-2012, 09:17 AM   #19
AHH, SPANS!!!
Rewards Points: 1,166
you are talking about a really thick wall past the inner plane of the wall. the best is to have horizontal blocking located in the wall along with taped drywall covering entire wall and then the T&G nailed with long finish nails through drywall and into the horizontal blocking along with being glued to the drywall. Horizontal blocking needs to be 16" or 24" layout...
hand drive is offline   Reply With Quote
installing tongue & groove plank paneling Big_T General DIY Discussions 1 04-16-2012 06:44 PM
How to match pine tongue and groove wall Roadking305 Carpentry 1 08-09-2011 09:15 AM
How to get wiring into wall with tongue and groove panels npn_ Electrical 4 03-05-2011 04:52 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 10:40 AM
Install Cabinets directly above Tongue & Groove? caezaar Building & Construction 13 07-06-2010 09:50 PM
