-   -   tongue and groove plank instead of sheetrock wall covering? (http://www.diychatroom.com/f2/tongue-groove-plank-instead-sheetrock-wall-covering-166095/)
gwilkrrs 12-10-2012 07:58 AM
i plan on installing all wood tongue and groove planks instead of sheetrock on my walls and cielings of my addition. my question is since i will be running the walls vertical i need something as a backer- should i use 3/8" sheetrock or plywood for this? i was even thinking about 1/4" masonite but it will be too flimsy and expensive i think...... thoughts?
rossfingal 12-10-2012 08:04 AM
Use 1/2 inch plywood - better nailing -
unless you're going to add "nailers" between the studs.
Even with "nailers" (blocking) - I would add 3/8 inch D-wall.
Don't use masonite.
"RF"
gwilkrrs 12-10-2012 08:07 AM
sorry should have stated before- no nailers between studs-
i guessded masonite would be a loser.
you figure 1/2 in stead of 3/8? i wonder about the windows and doors all needing jamb extensions then since that will be a thick wall.....
joecaption 12-10-2012 08:07 AM
No less then 1/2" sheetrock.
The other materials would be useless, just to thin or flimsy.
Still going to need at least one coat of tape and compound so there's no air leaks.
gwilkrrs 12-10-2012 08:11 AM
good call on the tape- i had thought the t-g would lock out the air but......
rossfingal 12-10-2012 08:24 AM
We've had success with adding blocking and 3/8 D-wall (glued) and screwed
to the studs/blocking.
1/2 inch - better!
At least one coat of tape on the joints.
T&G will not block the air out.
If you're going to install blocking - you can use 1 X 4 - turned flat side to the interior -
inside face of the studs.
More room for insulation.
"RF"
joecaption 12-10-2012 08:25 AM
They sell T X G as thin as 3/8 for walls and ceilings.
I use 1/2" to cut down on the spliting.
To fasten I've been using a narrow crown pneumatic staple gun.
The tip fits right on the radis of the tongue.
Good point about using plywood, I would use T X G plywood.
I'm just used to having to cover walls that have already been sheetrocked.
My bad.
Jamb extentions are really easy to make so do not let that scare you.
md2lgyk 12-10-2012 08:42 AM
I would also use glue. I have a hard time believing drywall would hold the staples very well.
I also suggest you consider leaving the ceiling or one wall with the drywall showing. I have a log house and can tell you that too much wood can be overpowering. We drywalled all the interior walls (the few we have) for that reason.
joecaption 12-10-2012 08:49 AM
I've been using this.
http://www.loctiteproducts.com/p/12/...-Cartridge.htm
Best part it's water clean up, no off gasing, no having to apply push the pieces together, pull them apart, wait, then reapply like some adhesives.
rossfingal 12-10-2012 08:53 AM
Depending on whether you're going to use plywood or D-wall -
the length of the fasteners, presupposes that: they are long enough to
penetrate (adequately) into the blocking/framing/substrate.
rossfingal 12-10-2012 09:12 AM
Also - whatever type of T&G you're going to use - 3/8, 3/4....
Get it into the place where it's going to be used - a week or 2 before the install -
After any D-wall taping has occurred!
Acclimation!
hand drive 12-10-2012 10:00 AM
Also, let the electrician know what you are using so the boxes and switches will be set out far enough, otherwise fire rings will be in order...
ddawg16 12-10-2012 11:16 AM
I would be inclined to want to use Type X drywall for fire protection....especially on the ceiling.....
gwilkrrs 12-10-2012 12:27 PM
thanks for all the suggestions! now for some research.....
jagans 12-10-2012 06:45 PM
Furring strips
Insulate between studs, staple plastic vapor barrier to studs, run 1 x 2 pine strips horizontally 16 inches on center as nailers for T&G. Buy windows and doors with jambs extended. You cant nail into sheetrock. I guess Plywood would work, but expensive. You definately want a pneumatic finish nailer or stapler that takes a 1.25 inch staple for this job.
