Toilet Leak + Wet Subfloor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 11:13 AM   #1
Hey all, thanks in advance for any guidance provided. I noticed my basement bathroom ceiling cracking so i knew i had a leak in the half bath directly above it on 2nd floor. I took the cracking section out and flushed toilet and saw water leak from sewer pipe. I looked it up and determined the wax ring needed to get replaced. When i pulled the toilet off, the old closet flange looked in bad shape so i decided to replace that as well.
My question now is, should i rip out hardwood flooring and replace subfloor or just let it dry out? (pic below). Any and all guidance will be greatly appreciated as im new to all this as im a 1st time home owner.
Thxs,
Will
Toilet leak + wet subfloor-image-2807006291.jpg   Toilet leak + wet subfloor-image-3751541470.jpg
wgarcia907 is offline   Reply With Quote
Old 07-25-2012, 09:58 PM   #2
Rewards Points: 1,092
if the subfloor is structurally sound, i'd hit it w/ 10% bleach, let it dry, and move along. if it is crappy wood, you have no choice but to replace it. btw: if need be, you can use two wax rings if there is a "bad height" problem. good luck.
Old 07-26-2012, 12:44 AM   #3
Rewards Points: 2,212
Instead of 2 wax rings get one with the plastic extension that is designed for this.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
wgarcia907 (07-26-2012)
Old 07-26-2012, 03:34 AM   #4
even better. good idea mae-ling.
The Following User Says Thank You to jklingel For This Useful Post:
Old 07-26-2012, 08:20 PM   #5
Hey thx for input/feedback. Ive read that when installing toilet over hardwood flange should be over hardwood as opposed to under. Is the attacked picture the type of flange with extension you're talking about? Should i put some wood around cutout hole so that flange sits above hardwood?
Thx again,
Will
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Leak at toilet feed pipe dunixi Plumbing 5 01-28-2012 06:08 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 01:31 PM
Phantom Toilet Leak lucasrt Plumbing 7 03-21-2010 12:56 PM
