Toilet Keeps Running - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 08:10 PM   #1
Toilet keeps running
After the toilet flushes and fills back up..I see water streaming in the bowl still..
anybody have ideas why? Thanks
al2468 is offline   Reply With Quote
Old 08-10-2011, 08:13 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The flapper has flopped.
XXX
Old 08-10-2011, 08:53 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
It'll quit running when it gets tired.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-12-2011, 12:23 PM   #4
Rewards Points: 29
Talking
That was Good!
spinfisher is offline   Reply With Quote
Old 08-12-2011, 12:52 PM   #5
Still Learnin'
The most likely problem is as mentioned above; your flapper has gone bad, which usually means it has warped over time so that it no longer holds a seal.
However, it might be a more simple problem. Make sure you have checked your tank to make sure nothing is getting hung up. In the past I have had the chain connecting the flapper and the lever wrap around the top of the bar shortening its length and preventing it from closing completely. You never know until you pull the top and look at it.
HitFan is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 01:53 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
