Toilet Flapper Closes Too Soon - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 02:29 PM   #1
Rewards Points: 12
Toilet flapper closes too soon
I just replaced a leaky flapper, fill valve and float mechanism. Now the trouble is the opposite of before: the flapper comes down too quickly before the flush is complete. I put a little float bobber on the chain right down near the flapper but to no avail. The flapper has "settings" for however much water per flush you use, 1-7. I have it set for the maximum. These settings do not seem to affect the air bubble inside of the flapper. Wife is getting cranky, been putzing with it for a week now. Any ideas, anyone? Besides marriage counseling that is.
dfiddler is offline   Reply With Quote
Old 06-10-2012, 03:07 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I'm no toilet specialist (that would be a funny job title) but maybe the chain is too long? So when you flush it's not pulling it enough so it just drops back from the pressure.
Did you try flushing it with the top off to see it in operation?
Old 06-10-2012, 04:11 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by dfiddler View Post
I just replaced a leaky flapper, fill valve and float mechanism. Now the trouble is the opposite of before: the flapper comes down too quickly ... These settings do not seem to affect the air bubble inside of the flapper.
put the old flapper back in?
are they the same type?
Old 06-10-2012, 05:08 PM   #4
ARB
Rewards Points: 99
I had the same problem (both with the adjustable flapper and cranky wife)... I called the flapper manufacturer (Fluidmaster) and they recommended to "force" the flapper adjustment past the maximum setting. Worked like a charm!
Hope you get the same results!
ARB is offline   Reply With Quote
Old 06-11-2012, 10:10 AM   #5
Ryf
buy a float for the chain or rope, they hold it open until the water is out, they usually need to be set very low on the rope. some flappers have a built in air void or are light enough weight that does the same thing.
if the flapper still isn't working, get a different design, they dont always work right especially if it came as a kit. preferably one like your old one, there are usually only 2 or 3 designs, so finding one that isn't a "universal" that works isn't usually to hard. hope this helps, I'm not a pro but I have been down this road with our toilets before, its annoying, but you will get it, luckily flappers are fairly cheap.
Ryf is offline   Reply With Quote
Replacing flapper in old toilet joeg679 Plumbing 5 11-11-2010 07:46 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet flapper keeps flipping backwards msammut Plumbing 2 07-04-2008 06:08 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
