Tinting (not Painting) Existing Cement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 04:38 AM   #1
Tinting (not painting) existing cement
Cement pad exists for 50+ years in a covered breezeway leading to my front door. I live in an area that rarely gets 25 degree weather for more than a week, usually mid-30's and above--and this is a protected area. It's cement gray-color. I'd like to make it a light terra cotta, but not really change the texture or re-do where the cracks have been filled over the years because as it stands would give it a more antique look. It seems pretty solid as a surface. Is there some way to do a "wash" over it? Even a few times, to get some good color on it without changing it's texture? I think painting it would give the wrong look altogether--too solid, not enough "movement." It's a bit rough to the touch, which is good, not slippery. I think it was covered with an indoor-outdoor rug which was not glued down for years.
readergal is offline   Reply With Quote
Old 02-09-2009, 06:51 AM   #2
There are(were) concrete stains, haven't used one in a long time. Check a local paint store or even a tile or concrete store. You will need to figorously clean the concrete, and probably an acid wash(muriatic acid) is needed. The stain has a mild acid that needs to be mixed in, follow directions carefully.
Old 02-09-2009, 08:55 AM   #3
Rewards Points: 1,220
If you are going to acid stain it (probably the best option) do not acid wash it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 02-09-2009, 11:54 AM   #4
Old School
Willie T's Avatar
Take a look at acid staining here.
Willie T
Old 02-09-2009, 04:31 PM   #5
The acid staining site , (thanks, Willie T) seems to have all the info I need. I was astounded at how complete it was. So, come end of summer, cocktails at my house! I'm sure I will have finished everything outside by then.
Sorry, I couldn't help but use those silly icons.
Old 02-09-2009, 05:09 PM   #6
Old School
Willie T's Avatar
It literally tickles me whenever I find a site like that where someone really tries to do a job the right way, and "bares all" in the telling.
Willie T
Old 02-09-2009, 05:24 PM   #7
I have trouble finding sites--was it on this DIY chat? I couldn't tell from the link. I did find a beaute for inexpensive (i hope) and creative fences . Pass it on if you'd like. http://www.ro-lu.com/
Old 02-09-2009, 05:32 PM   #8
Old School
Willie T's Avatar
I've found you can find a world of neat ideas on GOOGLE.... but you need to hit <images> after you have Googled a particular subject. Muchly cool way to search.
Willie T
Old 02-09-2009, 05:43 PM   #9
I'mputting you on as a "friend." I hopeit will make it easier to find you/respond to things.
Tags
coloring cement , flooring , prefinished cement
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 04:43 PM
Painting cement basement ?'s Dusty Painting 3 09-29-2006 06:27 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
