Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-04-2007, 12:12 PM   #1
tin walls and kitchen cabinets
Hello. My home was built in the 1800s and has tin walls in the kitchen. I know nothing about construction, so I don't know if there are studs behind the tin or if it is supported with some other material. I pulled a corner of the tin up, and it looks a little like lathe behind there. Currently, there are no upper cabinets on the walls. However, I would like to have some installed. Does anyone have experience with this sort of thing? Can cabinets be installed onto tin walls or must I take the tin down first? If it is, indeed, lathe instead of studs, is that sufficient for hanging cabinets, or does it need to be completely gutted? Thank you so much!
MKemnitzer is offline   Reply With Quote
Old 01-04-2007, 02:13 PM   #2
Since we cannot see the tin, I have to ask if it is a solid sheet of tin or the tin decorative tile-type panels? If it is the tiles, I would carefully remove them from the area behind where the cabinets will be installed. These are collector items and could be quite valuable. The new ones they are selling run about $20 a piece. Mostly used as ceiling tiles. If there is lath behind the tin, it is probably nailed to studs. The tin and lath would not support cabinets. You need to secure the cabinets into studs. Good luck with your project.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-04-2007, 05:17 PM   #3
Okay, great! They are large sheets of tin, not squares. Any way I can tell if there are studs under all of that tin and lathe? I have tried using a stud finder but it didn't pick anything up. Thanks again!
Old 01-04-2007, 05:52 PM   #4
Personally, I would remove the tin but you could try drilling small holes starting at about 16" from the corner of a wall and see if you hit a stud. The lath should only be about 1/4 to 3/8" thick so if you keep getting resistance, you most likely have hit a stud. I cannot imagine not having studs in the wall.
Old 01-04-2007, 08:22 PM   #5
Is there an interior wall on the opposite side if this tin wall?
Try your stud finder in it.
There has to be studs to hold up the roof or second floor.
redline is offline   Reply With Quote
Old 01-05-2007, 01:42 PM   #6
Thank you both for the tips! It's reassuring to know that there are studs somewhere under there; hopefully that means I won't have to rip out the historical tin! Thanks again.
Old 01-05-2007, 04:47 PM   #7
Try your stud finder on it.
meant to type "on" it and not in it.
Smoke on walls in kitchen diylady Painting 7 07-14-2007 11:09 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
installing kitchen cabinets ncoppola09 Carpentry 9 01-06-2007 10:07 PM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 09:02 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
