Tin Walls And Ceilings - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 03:57 PM   #1
Tin Walls and Ceilings
Last year we purchased a summer home on the northeastern coast of Maine. The house was built in 1899, and has tin walls and ceilings. A few people told us that we need to run the heat all winter, at a low setting, to avoid condensation due to temperature extremes, which could cause the tin to rust. The oil bills are killing us.
We would like to simply leave the heat off. Can anyone comment on the condensation issue? Will that really be a problem, or is that just a theory? Thanks
siovader is offline   Reply With Quote
Old 02-14-2013, 04:18 PM   #2
Rewards Points: 14,292
Lack of insulation in the attic impropper ventalation in the roof, no vaper barrer on the ground if there's a crawl space would be some reasons.
If humitys an issue why not just run a dehumidifier?
Old 02-14-2013, 04:28 PM   #3
Dehumidifier
I've thought about a dehumidifier. However, most have a tank that fills and must be emptied. And, we do not live there during the winter
Old 02-14-2013, 04:33 PM   #4
Set it on the counter and let it drain into the sink.
Old 02-14-2013, 04:33 PM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Most dehumidifiers also have a drain bung that you can attach a typical garden hose - then run that into a drain and call it a day.
hyunelan2 is offline   Reply With Quote
Old 02-14-2013, 04:34 PM   #6
DIY staff
Rewards Points: 7,174
1899???? My guess would be that the house has survived many winters without heat without issue.
Was the house always occupied before you purchased it or was it a summer home during its lifetime?
Old 02-14-2013, 04:38 PM   #7
The house was occupied for some winters, and unoccupied for others. The previous owner said that sometimes she left the heat off, and other years left it on. Thanks for the tip about the dehumidifier drain hose. We probably will look for a good unit and set it up that way. Has to be cheaper than $4.00/gallon heating oil. We also planned to fix the attic ventilation and install some more insulation.
Old 02-17-2013, 11:52 AM   #8
An old Tradesmen
Rewards Points: 8,154
Dehumidifier may not work, if the area gets below freezing. Since the drain hose or the drain will tend to freeze.
Old 02-17-2013, 12:18 PM   #9
Drain Freezing
What if we put the drain hose in a sink, such as in the kitchen?
Old 02-17-2013, 12:20 PM   #10
An old Tradesmen
So what is gonna stop that drain from freezing?
Old 02-18-2013, 07:14 AM   #11
Freezing
We may have to keep the heat on very low, say, 40 degrees. We are still looking for ideas, which is why I posted this. Thanks
Old 02-18-2013, 07:27 AM   #12
Nest Home Improvement
NestHI's Avatar
If it hasn't rusted in 100+ years it probably won't now. I would assume there have been many winters where there was no heat. Besides the properties within tin prohibit rust.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at www.NestHomeImprovement.com
NestHI is offline   Reply With Quote
Old 02-18-2013, 08:13 AM   #13
PoleCat's Avatar
Rewards Points: 1,652
Most dehumidifiers will ice up when ran in lower temperatures.
PoleCat is offline   Reply With Quote
Old 02-18-2013, 08:57 AM   #14
NestHI's Avatar
Very true.
Ideas for walls with cathedral ceilings Lamenz Interior Decorating 2 10-04-2011 05:36 PM
Linen cloth over plaster walls and ceilings shrtncrzy1109 Painting 2 02-07-2011 03:52 AM
Should I insulate Walls and Ceilings or not? williamj001 Building & Construction 6 07-24-2009 10:37 AM
Painting Textured ceilings? very textured! and walls Slickit Remodeling 3 06-11-2009 07:12 PM
Ceilings and walls??? Tdoggy187 Carpentry 22 02-29-2008 10:07 AM
