-   -   Tin Walls and Ceilings (http://www.diychatroom.com/f2/tin-walls-ceilings-171947/)
siovader 02-14-2013 04:57 PM
Last year we purchased a summer home on the northeastern coast of Maine. The house was built in 1899, and has tin walls and ceilings. A few people told us that we need to run the heat all winter, at a low setting, to avoid condensation due to temperature extremes, which could cause the tin to rust. The oil bills are killing us.
We would like to simply leave the heat off. Can anyone comment on the condensation issue? Will that really be a problem, or is that just a theory? Thanks
joecaption 02-14-2013 05:18 PM
Lack of insulation in the attic impropper ventalation in the roof, no vaper barrer on the ground if there's a crawl space would be some reasons.
If humitys an issue why not just run a dehumidifier?
siovader 02-14-2013 05:28 PM
Dehumidifier
I've thought about a dehumidifier. However, most have a tank that fills and must be emptied. And, we do not live there during the winter
joecaption 02-14-2013 05:33 PM
Set it on the counter and let it drain into the sink.
hyunelan2 02-14-2013 05:33 PM
Most dehumidifiers also have a drain bung that you can attach a typical garden hose - then run that into a drain and call it a day.
oh'mike 02-14-2013 05:34 PM
1899???? My guess would be that the house has survived many winters without heat without issue.
Was the house always occupied before you purchased it or was it a summer home during its lifetime?
siovader 02-14-2013 05:38 PM
The house was occupied for some winters, and unoccupied for others. The previous owner said that sometimes she left the heat off, and other years left it on. Thanks for the tip about the dehumidifier drain hose. We probably will look for a good unit and set it up that way. Has to be cheaper than $4.00/gallon heating oil. We also planned to fix the attic ventilation and install some more insulation.
beenthere 02-17-2013 12:52 PM
Dehumidifier may not work, if the area gets below freezing. Since the drain hose or the drain will tend to freeze.
siovader 02-17-2013 01:18 PM
Drain Freezing
What if we put the drain hose in a sink, such as in the kitchen?
beenthere 02-17-2013 01:20 PM
So what is gonna stop that drain from freezing?
siovader 02-18-2013 08:14 AM
Freezing
We may have to keep the heat on very low, say, 40 degrees. We are still looking for ideas, which is why I posted this. Thanks
NestHI 02-18-2013 08:27 AM
If it hasn't rusted in 100+ years it probably won't now. I would assume there have been many winters where there was no heat. Besides the properties within tin prohibit rust.
PoleCat 02-18-2013 09:13 AM
Most dehumidifiers will ice up when ran in lower temperatures.
NestHI 02-18-2013 09:57 AM
Very true.
